Sky InsuranceEM Tuning
    Jun 2009
    102
    Arrow ABS Computer Repair
    Hi all,
    So the ABS computer has been playing up for a year or so on my 1998 A4 1.8 SE (non turbo, fwd). Vagcom (or something similar at the time) said it was an intemittent memory error or something in the module.
    Now i've seen the PDF's about how to repair the connections inside the module, but i'm not sure if that'll resolve my issue above? Does anyone have the knowledge? I'd rather not send it off for repair if I can do it myself (I do some electronics work).
    Jan 2011
    Aberdeenshire
    646
    Try sending it to ECU Testing, they fix most ECUs, and fixed my DIS after BBA couldn't, and buggered it ( 2.5TDi tales of woe and fixes )
    I also have (had?) good electronic skills, but really, all you can do is open it up and check for dry joints as any component malfunction will not show. 10 minutes in the oven at 180-200C has been known to fix board joint problems on other PCBs, if you can remove any heat sensitive parts - and the Wife lets you.
    The other thing is, of course, the plug - Calling 2.5TDi Electronauts!
    I
    got caught-ish going down the most common route!
    1999 A4 B5 1.9 TDi FWD Saloon, Green SOLD
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine - and gearbox )
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    2006 A6 Allroad 3.0 TDi Blue, awaiting stuff to be done!
    jcb
    Sep 2005
    uk
    4,077
    BBA Reman did mine, turned around super quick and it has been faultless for the two years+ since done
    Jun 2009
    102
    Spoke to ECU Testing and they quoted me £100-200 + vat depending on the nature of the fault. IIRC the error that was logged before was along the lines of an intermittent memory failure, which if is the case i'm assuming it'd require the whole module replacing (didn't notice any flash/memory chips easily replaceable on this board).
  1. Abs ecu repair
    By jamie226bhp in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th January 2012, 17:13
  2. ABS pump repair?
    By deanski in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th June 2011, 22:55
  3. computer reset/computer location
    By 97_A4_1.8Turbo in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th January 2008, 20:36
  4. 8L A3 ABS Pump Fault & Repair!
    By Tallpaul in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th June 2006, 15:37
