Sky InsuranceAH Fabrications
Results 1 to 9 of 9
Thread: Can't open boot
    Nov 2011
    6
    Can't open boot
    Hi,
    I've just bought a B5 A4 TDi 110 SE and realised when I got home that I can't open the boot. The central locking seems to work fine, as I can hear the solenoid working. However, pressing in the lock button doesn't release the boot at all. I've also tried unlocking the boot from the key.
    Does anyone know what the cause of this could be? I can't see how I can access the boot through the cabin either.
    Thanks,
    Terry
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,907
    Is it facelift or prefacelift?
    TD5 Land Rover Defender build
    Nov 2011
    6
    It's a '96 prefacelift. My dad has a TDI 90 of the same year and his seats have a hatch which gives some access to the boot, but mine doesn't? There's more material behind the rear bench armrest.
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,505
    Did you not open the boot when you went to view the car? I always check everything, even under the carpets where possible for damage/rust etc etc
    2002 2.5 V6 Quattro
    Nov 2011
    6
    Nope, I dropped a bollock with this one I'm usually really thorough when viewing cars too!
    "Stick a V8 in it!"
    14,907
    Turn the key anti clockwise in the lock as far as it will go (circa 45degrees), then back to centre and remove, then press the button and it should open.
    Nov 2011
    6
    I just tried that and could feel the lock solenoid working, but pressing the button in didn't release the catch. I'm thinking the catch has come loose somehow? I've tried pushing down on the bootlid while I press the button to no avail.
    Is there a way of removing the rear seats entirely from the cabin, or is boot access required?
    Thanks for the help.
    "Stick a V8 in it!"
    14,907
    If its a FWD car theres a steel panel seperating the cabin from the boot, so your not climbing thru that way without use of an angle grinder!
    jcb
    Sep 2005
    uk
    4,070
    i have a sticky boot release at the moment and it will only open whilst the key is fully to the left.
    you can get into the boot, IIRC the panel has a "dotted Line" style access panel that only requires a few cuts to remove.
    had to do this on a 90 quattro I had
  1. Help - Boot will not open
    By V8Guzzler in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th April 2011, 22:10
  2. 2002 A3 boot won't open?
    By TonyA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th November 2010, 11:19
  3. Boot won't open?
    By Scouse in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th May 2010, 00:00
  4. Help - can't open boot
    By bantam1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th February 2009, 02:44
  5. boot will not open help!!
    By pottsey in forum Classic Audi Forum
    Last Post: 19th June 2006, 20:01
