Sky InsuranceEM Tuning
    Nov 2011
    6
    ABS & red exclamation mark light on
    Hi,
    I've just bought a B5 Audi A4 110 SE and the ABS light came on while I was driving it home. The red exclamation light is also flashing.
    Is this a common fault? It resets if you turn the car off, and comes back after driving for a while. Also, the brakes feel like the ABS is kicking in at times when it shouldn't.
    I'm just wondering what the cause could be and if it's expensive! I've scanned it with my universal obd2 scanner and no codes were found. I'm going to try and get it on VAGCOM tomorrow to see if that sheds any light.
    Thanks,
    Terry
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    It'll probably be a dodgy sensor or broken reluctor. Vagcom should tell you which corner to investigate.
    TD5 Land Rover Defender build
    Nov 2011
    6
    Cheers, I'll get the vagcom on it in the morning and see what's what. I've read about the ABS control modules failing, is this a common issue?
    "Stick a V8 in it!"
    14,900
    Module failure seems more common on Quattros than FWD's, but when they fail, they fail.
    Yours resetting with the ignition suggests just a simple sensor fault.
  1. ESP & ABS light
    By landopanda in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th May 2011, 18:32
  2. Replies: 28
    Last Post: 4th December 2010, 17:04
  3. ABS & Traction Control Light On... ABS Not Working
    By Gibonz in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th August 2010, 09:32
  4. ABS Light & Traction Control Light On??
    By wibble111 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th January 2009, 12:00
  5. Replies: 8
    Last Post: 19th January 2006, 23:06
