Chris NottEM Tuning
Results 1 to 14 of 14
Thread: Damp carpet
    gaz71's Avatar
    1.8T Quattro Sport AJL
    Jul 2009
    Torbay
    287
    Question Damp carpet
    Hi guys, can anyone help.I have recently noticed that the carpet in the rear passenger footwell is getting really wet. It is the one behind the drivers seat.I have had a look but cannot see any obvious reason or leak.Does anyone have any ideas what may be causing this?Thanks,Gareth
    To date - 2.5" Jetex exhaust, Generic re-map, Silicone hoses, N75k, shiny 17's, FK Springs
    Wanted - Sports cat, bigger downpipe, FMIC, Bigger turbo
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,691
    any other carpets wet?
    any side of the carpet wetter than others to help indicate the location of the leak?
    What does the damp smell like?
    A4 B5 Double Din, RNS-d, TMC, Full Sports Leather Heated with Leather Door Cards and Lower Door trims all for sale.
    Audrey's Build Thread
    RIP Audrey. She's being broken down.
    New Car, New Thread.
    Scott's Akoya Silver A8
    gaz71's Avatar
    Jul 2009
    Torbay
    287
    Quote Originally Posted by scott b5 View Post
    any other carpets wet?any side of the carpet wetter than others to help indicate the location of the leak?What does the damp smell like?
    No other carpets affected.Seems to be pretty uniform in dampness.Smells a bit like cat's piss, although I'm sure that cats are not the problem!
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,691
    Quote Originally Posted by gaz71 View Post
    No trapped cats recently then?
    Only thing I can think of it leaking heater matrix, but that would effect the front carpets more than the back.
    Leaking rear lights, but that would effect the boot as well.
    Leaking door trim?
    Blocked sun roof drain tube?
    1,892
    Had this on a mates A6 turned out to be the seal around pollen filter, think the water was traveling through the vents and entering out in the rear.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,949
    The water runs back due to the shape of the floor.
    Check the scuttle drains.
    TD5 Land Rover Defender build
    1,892
    the front carpet on the a6 was dry even checked under the front carpets just the rear was wet, so had to be going through the rear air vents.
    Once the seal was replace (the old one was shot) the water stopped.
    "Stick a V8 in it!"
    14,949
    Never thaught of the air vents!
    Blocked drains is the most common cause though.
    1,892
    Very ture, that was the first place I went to but nothing it was just about dry, also it only happen if the front end was sloping upwards!
    Jun 2003
    World of my own
    9,813
    You really have to lift the carpet in the front to see if it's wet as the foam underneath is really thick (like 3 inches), so it can be soaking underneath but bone dry on top. 99% it is blocked drain holes, just push out the rubber grommets so they won't get blocked again. It can even be dry underneath the battery as the water will eventually drain away but with a big downpour they can't cope and it overflows into the cabin and underneath the carpet.
    Alex Turner
    jcb
    Sep 2005
    uk
    4,070
    identical to mine,
    front dry, rear piss wet through
    push a long srewdrive down beside battery to push out the stupid grommets, then watch weaks of old cat piss flavoured water drain away.
    you can do it without pulling the battery even but that lets you clean **** out as well
    gaz71's Avatar
    Jul 2009
    Torbay
    287
    Managed to get a look at the car. Drain holes were clear but the one under the brake servo had been pushed down into the hole. After much struggling (and removal of lots of other bits) I have managed to retrieve it and get it fitted as it should be. Just got to dry the carpet out to see if the issue is fixed, although things do look promising as it pissed down yesterday and the carpet doesn't have a puddle on it :o)
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    577
    Really you should just remove the grommet to ensure free draining. Why they were ever fitted at all is beyond my thinking...
    2000 1.8t quattro Sport totally standard (ish)
    Jun 2003
    World of my own
    9,813
    Yes, don't refit the bloody things they are the cause of the issue. The second time mine flooded they weren't blocked with leaves or debris, they were blocked with a fine silt.
    Alex Turner
  1. Damp passenger footwell
    By subtle in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th January 2011, 16:56
  2. Damp in the footwells
    By LD3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th December 2010, 20:27
  3. Damp carpet behind drivers seat in Sportback
    By Hollywout in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th September 2010, 17:38
  4. CARPET RIGHT! Or CARPET WRONG?
    By Dazmo in forum Rants & Raves
    Last Post: 8th May 2010, 12:59
  5. How to dry out a damp car?
    By voteforpedro in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd January 2009, 20:45
