AH FabricationsEM Tuning
    Jan 2011
    Aberdeenshire
    628
    Steering rack play
    I went in the other day for wheel alignment, and was told I had play in the passenger side of my steering rack.
    I had a look with the guy, and there is definitely play that appears to be from the rack, and not from the bushings/bearings as I could see the rack arm moving with the wheel. The other side has no play. I've not come across a rack wears on one side only before, so:-
    Is this common, and is it the rack, or something else?
    Assuming a rack, can I repair it, or is it new rack time?
    1999 A4 B5 1.9 TDi FWD Saloon, Green
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine)
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    Nov 2010
    Stornoway, Scotland
    68
    You need an inner tie rod, nothing terminal at all. About £30 aftermarket or £60 OEM.
    I'm very surprised the mechanic couldn't tell you that, it's not particularly un-common on any make of car.
    Head start?!?!
    Turbo lag, there's your head start!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,905
    Probably a tyre monkey in a fast fit outfit!
    TD5 Land Rover Defender build
    Nov 2010
    Stornoway, Scotland
    68
    It probably is, I'd suggest a change of garage if that's the case, wouldn't fancy that mechanic doing my wheel alignment that's for sure.
    Head start?!?!
    Jan 2011
    Aberdeenshire
    628
    Thanks, guys,
    Yes, it was a local tyre fitting shop.
    I'm surprised I've not seen it before myself - but ho hum.
  1. Steering play! Rack or tie rod ends??
    By Steveo_A3_1.8t in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th May 2011, 10:29
  2. Play in steering rack Q.
    By S3 finatic in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th February 2011, 20:43
  3. Steering rack play
    By A3Sport in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th December 2006, 20:17
  4. Creaky steering - PtII, after a new steering rack
    By OutLore in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd February 2006, 18:58
  5. Help with steering play
    By imported_velcrobix in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th September 2005, 19:05
