Results 1 to 9 of 9
Thread: Grounding Kits
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,752
    Grounding Kits
    I was wondering if anyone has tried this on there A4?
    The owner of this Cupra has and has noticed some changes.
    Grounding
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    Re: Grounding Kits
    I read about this before and it said it did work, the only problem is they don't make one for the Audi.
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Re: Grounding Kits
    Following his discription you could probably make one your self with some nice red cable.
    I might give it a go as well the only pic that you don't see is the one to the coil packs.
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Re: Grounding Kits
    Here just seen one if you go to buy it now.
    There is one for the passat which is the same enigne position etc as the A4.
    I may just have to get one as reading all about it they seem to make a dfference.
    Might be where my missing 30+ HP is.
    http://www.4grounding.com/
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,752
    Re: Grounding Kits
    I think i am going to try one as well.
    I wish i had some instructions on how it goes though. Whats daisy chain wireing?
    Jun 2003
    Hythe, Kent
    1,180
    Re: Grounding Kits
    [ QUOTE ]
    [/ QUOTE ]
    I assume daisy chaining means just connecting them together one after another...
    i.e.
    Battery to chassis
    Chassis to alternator
    Alternator to... and so forth.
    Or I may be totally wrong and look stupid right now [img]/ubbthreads/images/graemlins/frown.gif[/img]
    Kev.
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Re: Grounding Kits
    That is right one after the other etc = a daisy chain.
    Oct 2004
    Southampton, England
    86
    Re: Grounding Kits
    point a, this guy is a bit of a toss piece from my experience
    point b, you "shouldn't" notice any difference with this mod, Unless the original grounding on the vehicle is sub-standard or failing.
    PaulRS3's Avatar
    UK
    1,006
    Re: Grounding Kits
    running it on my S3, for year or more now.
    did notice it smoother (placebo effect??) when i first test it then it dissapeared into the norm.
    i was sceptical, as whilst theory is there, the standrad earthing was very very good.
    im a sparky by trade so I tested before and after results with a fluke, and TBH there was negligible difference.
    but where it _may_ help is under load out on the road, and when temps soar ... but still not proven
    if i took it out now, i doubt id miss it, but as its installed and hidden, ive left it in.
    i made my own up with gold plated audio crimps and cabling.
    its a cheap mod, that is removable, but dont expect much.
