AH FabricationsChris Nott
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    S4 Remap = new problems
    I've just had the ECU remapped. Feels better and more responsive... but, when it gets to 4000rpm it misfires and has trouble getting past there.
    The VagCom reads a few codes, as follows:
    17800 - camshaft position sensor bank 2 (G163): Open Short to Plus
    P1392 - 35 - 00
    17965 - Charge Pressure Control: Positive Deviation
    P1557 - 35 - 00
    Where is the cam position sensor on bank 2 located so I can whip it out and check for 'stuff@ (or replace it)
    Also, what does the second reading mean?
    NEW 6 cylinder 40mm front springs - £40
    PM me for more info
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,389
    Second ones a boost leak. Unplug the N75 and drive like a granny until you fix it, or you'll be replacing the turbos.
    Common places are the throttle body boot, and the F hose. Worth pressure testing the whole intake though. Who mapped it? the well known S4 tuners would typically have boost leak tested the car before going ahead, and for good reason.
    Bank 2 is the left hand bank (passenger side) The cam sensor is mounted on the rear of the cylinder head, on the end of the intake cam. Check its plugged in properly i guess.
    TD5 Land Rover Defender build
  1. Possible Remap Problems?
    By scott6452 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th April 2011, 01:18
  2. remap problems or not
    By tdimax1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th February 2008, 21:03
  3. Turbo problems after remap
    By bigjim in forum Tuning
    Last Post: 30th January 2008, 19:34
  4. boost problems - following remap
    By tim99 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th May 2004, 12:59
  5. Anyone had any problems after remap?
    By 18ME in forum Tuning
    Last Post: 31st July 2003, 08:31
