EM TuningVolks Autos
    Sep 2011
    Sunny Bangor. N.Wales.
    288
    Question Strange Pipe On A 2.5TDI
    hi all, after changing my airfilter and "hoovering" the airbox too, there is what seems to by a pipe in the bottom of the airbox, the kind that use to be used as a heaterpipe off the manifold in cars yrssssssss ago.
    any ideas the point in it, as it only goes to a small hole in the base of the airfilter box :S
    2000, A4 2.5Tdi Quattro.
    Tinted, 3600WATTSLoud
    Sep 2011
    288
    any idea's anyone?
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,505
    A couple of pics might help.....?
    2002 2.5 V6 Quattro
  1. Size of boost pipe from turbo to charge pipe
    By gez in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd April 2011, 20:50
  2. Replace pick up pipe naturally, also clean oil feed / return pipe?
    By mikem1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th March 2011, 18:05
  3. custom down pipe or pipe werx down pipe
    By s3gazz in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th October 2010, 20:23
  4. a4 2.5tdi same engine as a6 2.5tdi help pls?????????????
    By davidfox280585 in forum General Automotive Chat
    Last Post: 1st May 2010, 19:12
  5. Split Pipe, But dont no the name of pipe! sounds like I have A Dump Valve!
    By VTI_EG_DAN in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th February 2009, 13:12
