JMB RetrofitsChris Nott
Results 1 to 11 of 11
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,095
    Worth adding an EBC?
    Basically my brother has offered me his aftermarket EBC from his project car at a very attractive price. Is it worth grabbing for my old tank?
    Life begins at 140mph
    www.passionford.com
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,095
    Anybody?
    www.passionford.com
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,388
    What are you trying to achieve with it?
    If you adjust the boost much outwith the stock parameters you'll just cause the ECU to cut the fuel and drop into limp mode.
    TD5 Land Rover Defender build
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    whats an ebc?
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    "Stick a V8 in it!"
    15,388
    Quote Originally Posted by olds_kool View Post
    whats an ebc?
    Electronic Boost Controller
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,095
    Just thought it may give me better control of the boost and it's delivery, maybe even squeeze a couple more psi of boost from it as it's just too limp with 12psi Looking at getting the Quattro map remap written to a FWD chip to eek a bit more from the old fun bus
    www.passionford.com
    "Stick a V8 in it!"
    15,388
    Isnt your car the early ECU type? I doubt the later flash would be compatible if so.
    I have a 557B box from an A6 that might take the later rom, but you'd need to change to the later harness too.
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,095
    When I had it chipped it did have to be done the old school way by soldering a chip into the ECU.
    www.passionford.com
    "Stick a V8 in it!"
    15,388
    Yeh, but the TQS uses the later style of ECU. Two big plugs and a slim rounded case.
    Your car (i think) has the earlier ECU with the big square case and 5 seperate plugs.
    Your not going to be able to put the later chip into the earlier box.
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,095
    I was hoping to put the newer map onto the older chip. Could really do with a proper look inside both but saddly that won't be easy to achieve.
    Was going to swipe the ECU off the Quattro breaker but saddly that all fell through
    www.passionford.com
    "Stick a V8 in it!"
    15,388
    The chips are defo different. The chip used on the earlier ECU is rare and hard to get hold of now.
  1. Ebc brake pads?
    By Jonezy87 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th June 2010, 17:28
  2. EBC Brakes
    By luis.filipe in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th October 2007, 11:08
  3. EBC Greenstuff pads.....???
    By Platinum70 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th February 2006, 09:15
  4. EBC Brakes??
    By Anito in forum Tuning
    Last Post: 21st May 2004, 08:15
  5. New EBC brakes.
    By Gambba in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st May 2003, 18:10
