Volks AutosChris Nott
Results 1 to 17 of 17
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,388
    A4 1.8T Running Issues
    I've been chasing a weird running issue with my parents 1.8T for a while now. I've tried everything i can possibly think of, but just aint getting to the bottom of it.
    The original problem was really harsh juddering, mostly at low/medium revs with lots of throttle. You could plant the boot at 2500rpm and it would pull, then it would judder harshly (sort of like someone was turning the engine off momentarily)
    I changed the Coils and ICM for spares, and it got slightly worse. I swapped my spare MAF in, and it stayed the same. I changed the plugs and it got marginally better.
    Then i discovered a split hose on the inlet manifold, running to the PCV gubbins, ie a huge boost leak. Repaired that, and the cars much better.
    However its still not right. At random it still judders. Much less frequently and much more randomly, but still happens. Also now, if you give it full throttle in fourth gear say, you can feel constant very slight hesitation. It doesnt just smoothly climb thru the revs, theres constant small judders, somtimes so slight it just feels like a slight reduction in power output momentarily.
    I'm going to swap the coils with the ones off my own car, as i know for sure they're good, and i'm going to refit the original MAF sensor incase the one i've fitted is slightly dodgy and was masked by the boost leak.
    Any other ideas?
    TD5 Land Rover Defender build
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Pretty much as you've said, swap the components back that you did initially incase these 2nd hand units may be faulty, then take it from there. How are HT leads etc?
    Project RS28 build
    Brendan12's Avatar
    May 2011
    Birmingham
    142
    Tired swapping the N75 valve?
    Now - Ford Focus RS (305 bhp) - 2009
    Previous Cars
    A4 2.0 TFSi S-Line (251 bhp) - 2005
    Audi A3 3.2 Quattro Sport (250 bhp) - 2004
    Ford Fiesta ST (150 bhp) - 2006
    Ford Focus ST2 (290 bhp) - 2009
    Skoda Octavia vrS (215 bhp) - 2001
    Volkswagen Golf GTi Turbo (230 bhp) - 2001
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    Seems like youve checked/replaced the obvious components.
    Fpr, injectors or throttle body maybe ??
    I no when I had a judder one of the coils was shot which developed to a missfire at idle.
    "Stick a V8 in it!"
    15,388
    It doesnt have HT leads, individual coils on a 1.8T.
    I have a spare set of injectors and a spare FPR at home. Maybe i should send the injectors to be cleaned and then swap them in to rule that out.
    I've not touched the N75, but i did wonder about unplugging it and seeing if the oddness remained or if it went away. Unfortunately it doesnt actually help, because an ignition issue is going to improve with less boost, as might a MAF issue (less airflow) etc. So you might end up thinking its the N75 and swapping it out for no reason!
    Jul 2007
    London
    3,252
    How's the fuel filter ?
    FOR SALE:
    "Stick a V8 in it!"
    15,388
    203000miles old :P
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    579
    Was the ICM a good spare? Dunno what sort of advice you were looking for really Kev coz if you don't know what's up with it I doubt anyone else will! and there was me thinking you know everything about these motors lol
    2000 1.8t quattro Sport totally standard (ish)
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    Quote Originally Posted by NineNails View Post
    Jun 2011
    Great Melton Norfolk
    1,356
    could be fuel filter , i had a vr6 that wouldn`t rev and turned out filter was blocked.
    macpdm's Avatar
    Jul 2011
    Cheshire
    409
    I have been having all sorts of running issues myself until we plaved around with the DV by manually pushing the plunger in and out and cleaning it we also cleaned the throttle body.So far touch wood its been a week and still running fine.
    Admittedly the symptons I was having was loss of power where it felt like I was loosing boost.
    "Stick a V8 in it!"
    15,388
    I dont think its fuel related, because if you use the full RPM band its fine. EG if you rev it right out to the limiter, it pulls mostly fine. The juddering all seems to happen around the middle of the rev range, ie peak cylinder pressure/peak torque. Today, third gear 30mph, full throttle, it started to accellerate then BRRRRRRR juddering and complete loss of power.
    I tried refitting the other maf today, no change.
    I'm going to take the four known good coils from my car and fit them to it tomorrow. Might as well throw the ICM in as well. That way i know every ignition component from the spark plugs back is perfect.
    Assuming its not the coils, my thaughts at the moment are:
    Another Boost leak - I've looked as best i can, but maybe theres something else lurking away somewhere. Really need a pressure tester to diagnose this properly and i dont have a compressor to hand.
    Faulty MAF - I have two, and swapping between them doesnt really seem to change the symptoms, but i guess they both could be faulty as they are both 14 years old.
    Fuel Delivery (Pump/filter/injectors) - Seems sort of unlikely as it does pull thru the dodgyness and seems to deliver full power.
    Faulty coil wiring - long shot, if it was faulty why would it only cause problems at peak load. Unless it was a grounding issue and the coils are being starved of power...
    Faulty ECU or Harness - getting to be a serious long shot as to why it could cause missfires at the very odd times that it does.
    Aug 2010
    3,138
    That sounds exactly like what mine was doing after the FT install as the car was running hardly no boost before then when it was back to peaking 12-14psi it would knock one coil out during boosting but like I said That was shortly noticed at at idle.
    Have you had the plugs out to check there no signs of arcing up the sides of the plugs ??
    "Stick a V8 in it!"
    15,388
    Brand new plugs went in on Thursday. No change.
    It drives perfect if you dont load it up. Idle is smooth. Just passed its MOT so i presume emissions are spot on.
    Maybe theres a dodgy coil in both sets of four...
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Had a similar miss on a Cosworth years ago, only noticible in certain gears under mid to heavyish acceleration, turned out to be the crank sensor going.
    Sounds more electrical than fuelling etc.
    Project RS28 build
    IN 2 Deep's Avatar
    Hoonigan
    Oct 2009
    Lancashire, UK
    379
    Check the coil pack wires, they tend to get a tad brittle over the years and can cause the most annoying intermittent faults, have you checked the TPS is reading ok? Sounds to me like a wiring issue over a sensor issue. If you've ever taken a loom apart you will know that all the grounds, postives etc are all commoned together under a mile of tape on the ecu plug end, that to me is a ball ache waiting to happen. Sounds like one of those issues that's gonna test your metal
    2000 Audi A4 B5 Quattro Sport - My build thread - Click
    2004 Volvo S60 D5 - Daily smoker & race car tow truck
    1993 Audi S2 ABY - Dead & buried
    1990 Audi Coupe 2.2E - Dead & buried
    "Stick a V8 in it!"
    15,388
    Well its fixed.
    I fitted two of the original coils to my car and drove it around for a day with no issues, so i now had 6 coils i knew for sure was good.
    So i then took four of those 6 and swapped them in.
    Fitted two of the removed coils to my car and now both cars are working fine. i did it that way so if my car then started exhibiting the symptoms it could only be one of two coils.
    Having talked it over with dad, we recon one of the replacement coils was faulty, but the original problem was caused by the boost leak. He says the car got distinctly worse when i changed the coils. So the original juddering has been the leak. I've fitted a dodgy coil when trying to fix it, then later fixed the leak, leaving only the faulty coil!
  1. Running Issues at Cold
    By Funkyfin2000 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th December 2013, 20:35
  2. Audi A3 3.2 V6 DSG Running Issues***ADVICE PLEASE***
    By phil08 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th July 2012, 02:38
  3. 3.2 RUNNING ISSUES PLEASE HELP ME !
    By LEESMITH in forum General Technical / How To
    Last Post: 13th July 2011, 14:12
  4. B5 1.8t running issues! Help PLEASE!
    By s11pyk1234 in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th September 2009, 00:12
  5. Running Temp Issues
    By Ian W in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th November 2007, 19:15
