what can i do with the vagcom lite, i need to program a key to my car an also might need to re-inline my throttle body, can i do this with the lite version
Can you not do a throttle alignment by disconnecting the battery for half an hour and then reconnecting and turning ignition on but NOT actually starting the engine?
Throttle body can be done with bonnet open and drivers door fully opened and turn ignition on and leave until the TB stops making a high pitched whine. Works this way on my 98 V6.
