Badger5Chris Nott
Results 1 to 7 of 7
    Jun 2010
    East Grinstead
    ABS warning light at 70+mph????
    Hi guys I'm hoping for some advice on this problem with my A4 avant 1.9 tdi 1998 basically I have changed the rear discs, wheel bearings and pads now as soon as I hit 70 on the motorway the ABS light comes on and stays on till I turn the car off? Below 70 it's fine have checked for play in the wheels/ discs but have none?
    Thanks in advance
    Xander
    Sep 2010
    498
    I have this exact same problem on my A3 8l. Very annoying.
    Jan 2011
    Aberdeenshire
    646
    You've either knocked the abs sensor a gnats danglies ween doing the bearing, or have a damaged reluctor. I'm sure I have a cracked reluctor, and I get this after about an hour at 70. I also have the low speed pulsing issue.
    It's the constant vibration that changes the gap and trigers the fault.
    The good news is that VCDS will tell you which wheel is the problem if you had the light on at any point.
    1999 A4 B5 1.9 TDi FWD Saloon, Green SOLD
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine - and gearbox )
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    2006 A6 Allroad 3.0 TDi Blue, awaiting stuff to be done!
    Jun 2010
    East Grinstead
    Ok have checked the sensors had a tiny bit of movement just need to take it for a run to see. Now this will sound stupid but what is VCDS??
    Jun 2010
    East Grinstead
    Ok abs light sorted had a quick blast up the motorway and no warning light😜must have knocked it when I was fighting with a wheel bearing that had completely des integrated cheers for the advice guys
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,600
    Always good to hear when faults are so simply rectified.
    VCDS is vag-com diagnostic software for reading the ECU and pulling the DTC codes up. Also, with a fully registered version you can also program some changes to the car. But nothing like remapping the ECU, Thats different. You can change things like BOSe/NON-BOSe on the stereo, change auto sport boxes into permanent sports mode and lots of other things.
    Have a read from here: Ross-Tech Wiki
    Dan
    2002 2.5 V6 Quattro
    Jun 2010
    East Grinstead
    Thanks Dan I'll have a look now all I need to do it get another rim as a pothole dented the outside lip and no companies near me will repair it so it a new one gggggrrrrrr!!!!!
  1. ABS light and warning light comes on if parked still for a while
    By SuziA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd September 2011, 16:21
  2. A4 ABS Warning light on - please help!!!!!!
    By Big T in forum General Technical / How To
    Last Post: 20th February 2009, 10:55
  3. ABS Warning light
    By macca666 in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th September 2007, 22:30
  4. ABS warning light
    By imported_jimbogrey in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st December 2005, 21:13
  5. ABS warning light
    By jgrand in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th October 2004, 07:53
