Volks AutosChris Nott
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    577
    Quick throttle body question
    I want to take my tb off for a clean. Is it really necessary to replace any gaskets or can you get away without? Would it benefit from a clean? I wouldn't imagine it's ever had one...
    Ta
    Si.
    2000 1.8t quattro Sport totally standard (ish)
    jcb
    Sep 2005
    uk
    4,070
    if it ain't broken.,.....
    can clean it in situ if you really want to.
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,633
    as above, but if you really must take it off you should really use new gaskets as the old ones will have deformed/squashed, and run a throttle body alignment with vagcom once its put back together...
    Currently rolling in a SKODA!!!
    NineNails's Avatar
    Sep 2006
    North Wales
    577
    I hear what you're saying and I agree but I think there may be the beginnings of a problem with it. The revs have started to dip below idle a bit when I pull up to junctions etc. Also I have a problem I detailed here >> Odd Idle Problem Think I might just try an adaptation first before I go pulling it to bits unless anyone can shed some light for me
    Oct 2009
    Melb, Aust
    48
    What do you mean clean the throttle body? The inside around the butterfly valve? I hear of people doing this all the time, I think it's a ridiculous idea. Unless it's full of carbon which it won't be. Bad idle can be caused by air leak, maf, spark plugs, dirty injectors and a few other things.
    96 A4 1.8TQ
    K03-073, 1 BAR CHIP, PORT N POLISH HEAD, SUPERTECH VALVES, JE PISTONS, SCAT RODS, FIDANZA FW, SOUTHBEND STG3, CUSTOM AIR BOX, 034 HIFLOW MANIFOLD, 034 PHENOLIC SPACER & FIBER GLASS INSULATED INLET MANIFOLD.
    'TO COME'
    2.5 IN EXHAUST, BILSTEIN H&R.
    NineNails's Avatar
    Sep 2006
    North Wales
    577
    Ok just to update....
    I didn't bother taking off the body. I just took off the pipe and squirted a bit of carb cleaner up the body and wiped it out with a rag and got loads of black crud out of it and took my time making sure I got the butterfly edges as clean as I could. I then ran the alignment with vagcom. When I first went to meas block 98 the end field said ERROR but after I ran it it said ADP:OK.
    Seems Problem solved....so far
  1. Question about the throttle body
    By bengal in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th November 2010, 18:26
  2. Throttle Body trick / Question
    By dantdi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th November 2009, 18:30
  3. Throttle Body
    By a3daveo in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th June 2007, 23:35
  4. Where is my throttle body?
    By Defratos in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st April 2005, 11:46
  5. Throttle Body
    By imported_Cali in forum General Technical / How To
    Last Post: 22nd July 2004, 22:40
