Results 1 to 9 of 9
    jcb
    Sep 2005
    uk
    4,077
    rusted hub bolt has no edges!! urgent help!
    have started to sort my rear bearing but the bolt is well rusted and there is nothing to get hold of.
    I dont have a suitable 12 point or spline bit to hammer in and was thinking if I remove the wheel I could weld a nut/bolt on the end of the stripped hub bolt.
    never fecking easy!
    question:
    any other options?
    if I do go down the welding route do I really need to disconnect battery/alternator/ECU or any/all of them?
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,135
    Air chissel and a pair of ear defenders ! Lol
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    i dont think a hammered in spline bit would work anyway, its just too tight.
    Stick your 14mm hex in the hole and weld it on, then undo.
    TD5 Land Rover Defender build
    jcb
    Sep 2005
    uk
    4,077
    so what do I really have to disconnect to weld?
    "Stick a V8 in it!"
    15,370
    The hubs surely electrically isolated from the rest of the car anyway? its all rubber mounted...
    "Stick a V8 in it!"
    15,370
    Saying that, its bolted to the diff, which bolts to the shell.
    Unplug things if you want, i've welded bits before and didnt bother.
    I cant see how it can cause a problem, its a completely seperate circuit to any of the cars electrics.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    Ive not bothered, not had any probs so far.
    jcb
    Sep 2005
    uk
    4,077
    fecker is off.
    big hammer, disposable bit and a fecking long bar!
    had to get assistance on the bit
    "Stick a V8 in it!"
    15,370
    good stuff!
  1. S3 rusted brake and rear window question
    By kularm in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th August 2009, 12:15
  2. Hub Bolt Torque
    By d4mo in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th May 2009, 01:13
  3. Front hub bolt torque figure, S3
    By woody1302 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th October 2007, 11:43
  4. Help - Serious wear on the inside edges of front tyres.
    By noodle in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th March 2006, 15:36
  5. Bolt size for the hub on a 1999 A4 Quattro Turbo
    By swsimon in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th June 2004, 18:56
