Sky InsuranceChris Nott
    Oct 2011
    help non starter
    I recently purchased an Audi A4 Avant 1.8 non turbo V5 on engine casing.
    The car had an aftermarket alarm fitted that was playing up, so I removed it, the alarm wiring was just spured in the harness so I cut it out.
    The car will not turn over the starter motor does not spin, I can hear the solinoid clicking. However under the steering wheel on the relay block
    there is a row of four relays, position three and four are missing, I did remove a relay that was in the alarm and I am wondering if these missing realys
    are causing the problem of the car not starting, I cannot replace them I have nothing to go on, any help would be really appreciated.
    Many Thanks
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    If you look down the back of the engine behind the inlet manifold, you'll see the wiring harness clipped on down the back.
    Around that area is a single pin connector, which carries the starter solenoid feed from the car harness into the Engine. Its black wire with a red stripe, and the wire goes into a piece of corrugated tubing which runs across the back of the block and round towards the starter.
    If you pull this apart, and run a jumper wire from the battery positive to the engine side of this connector and see if the starter spins. If it does theres something wrong with the cars internal wiring, such as your alarm removal.
    TD5 Land Rover Defender build
    Oct 2011
    ok I will give that a go, mechanic was supposed to look at it tonight but he never turned up!
    Still confused about about the relays,
  1. Starter for 10
    By Sandra in forum Movies
    Last Post: 23rd August 2011, 10:57
  2. New Owner - Hello and a starter for 10 !
    By marcuss3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th November 2010, 19:31
  3. Non Starter
    By john24susan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st June 2008, 03:35
  4. Non Starter
    By PJLarge in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th May 2007, 17:00
  5. Non-Starter
    By neomaximus in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd February 2006, 21:54
