Volks AutosAH Fabrications
Results 1 to 10 of 10
Thread: S4 Tracking....
    AndyC's Avatar
    Apr 2003
    Dorset
    716
    S4 Tracking....
    been fiddling with tracking on my car as we have some laser kit at work..
    for some odd reason I decided to set the front toe to parallel, at the time if felt tighter.....
    4 weeks down the line it had started to feel crap and annoy me,
    so I reset to 2.5mm toe out and it feels a ****e load better........
    free upgrade!
    there is no such thing as bad weather, just the wrong clothes!!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,320
    audi specify 10minutes toe out per side on the front and slightly more on the rear.
    TD5 Land Rover Defender build
    AndyC's Avatar
    Apr 2003
    Dorset
    716
    without looking it up what is 10mins in MM
    "Stick a V8 in it!"
    15,320
    I think it depends on the wheel diameter?
    A quick look online suggests that 2.5mm on a 17" rim is almost exactly 10mins.
    AndyC's Avatar
    Apr 2003
    Dorset
    716
    not considered the wheel dia' before tbh. but its the distance about the pivot I guess
    jcb
    Sep 2005
    uk
    4,077
    the toe out helps drag the fat lazy agricultural quattro system round corners.
    I personally use less than spec but not as much off as being zero (parallel).
    saves the front tyres and gives a bit more neutral handling with the appropriate rear adjustment
    "Stick a V8 in it!"
    15,320
    Toe out makes any car feel more lively.
    Obviously theres a balance against tyre wear and as such most ****/non-performance cars will specify very little, and really **** ones designed for old farts that cant see will even have toe in to make the steering numb and the car unwilling to turn so they dont end up wandering around the road!
    Oct 2009
    Melb, Aust
    48
    Toe out will cause the front to wander or dart when driving in a straight line. A few mm of toe in is the best and reduces tyre wear.
    Did you check the rear toe? It's adjustable with concentric bushings.
    96 A4 1.8TQ
    K03-073, 1 BAR CHIP, PORT N POLISH HEAD, SUPERTECH VALVES, JE PISTONS, SCAT RODS, FIDANZA FW, SOUTHBEND STG3, CUSTOM AIR BOX, 034 HIFLOW MANIFOLD, 034 PHENOLIC SPACER & FIBER GLASS INSULATED INLET MANIFOLD.
    'TO COME'
    2.5 IN EXHAUST, BILSTEIN H&R.
    AndyC's Avatar
    Apr 2003
    Dorset
    716
    of course
    although toe in on the a4 caused tire wear!
    "Stick a V8 in it!"
    15,320
    toe in makes the car feel numb and pretty crappy tbh.
    Audi specifies toe out for very good reason!
  1. Tracking? or something else?
    By jackj in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th April 2011, 14:12
  2. Tracking on the S3
    By S3MHT in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd July 2008, 15:15
  3. Tracking: How Much...?
    By S3PEG in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th May 2008, 13:17
  4. Can't get the tracking done!
    By robonmac in forum Classic Audi Forum
    Last Post: 10th May 2007, 20:25
  5. Tracking
    By ianmack in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th June 2003, 12:47
