Chris NottSky Insurance
    jcb
    Sep 2005
    uk
    4,077
    central locking pump problem
    in my ongoing issues with my car....discovered a new one.
    pump runs for a good 30 seconds on entry
    boot lock doesnt always open on fob and has to be opened manually with key. after I have done that it seems to work fine.
    so...
    1) could a sticky mechanism be stopping the pump from cutting off as it cant open the boot lock.?
    2) how does the pump know to stop pumping?
    3) would a leak in the boot line be able to cause this?
    4) should I torch this fecking thing and take the £5k it is insured for!?!?!?!?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,384
    You have a vacuum leak, and if you dont sort it pronto the impeller in the pump will shatter.
    Pump stops pumping once it reaches a desired vacuum pull, or after a timeout if the vacuum pull never happens.
    You'll need to trace round the vac lines and look for a leak. Given the dodgy boot, it might be an idea to start there.
    TD5 Land Rover Defender build
  1. central locking pump
    By Aaronneal in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th September 2011, 19:22
  2. central locking pump
    By johnsykes in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 4th April 2011, 20:01
  3. Central locking pump on it's way out?
    By Duck in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th February 2010, 18:28
  4. Central locking pump help
    By con1.8t in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th October 2009, 08:22
  5. Central locking pump help
    By floyd 1.8 turbo in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th September 2009, 17:30
