Chris NottSky Insurance
Results 1 to 10 of 10
    A4Steve
    debadging rear HELP
    hi peeps
    after reading the audiworld forums ive decided to do a few more mods, beetle sunglasses, s4 aluminium trim, but firstly debadge (leaving just the rings)
    this is the method ive read in basic: Heat up badge using hairdryer until feels hot then use dental floss to prise away
    My problem is that the yanks have used a product called "goo gone" to remove the adhesive left over- but dont think that is available in uk
    Does anyone know any equivalants in uk that wont damage paintwork?? [img]/ubbthreads/images/graemlins/hug.gif[/img]
    thx yaseen
    red Rieger kitted 95 a4
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    Re: debadging rear HELP
    Pur a few jugs of boiling water over the badge, and if that dnt move it, then use a hair dryer...
    Use a thing called 'stick stuff remover' which surprisingly, removes sticky stuff... its based on citric acid(lemon juice) so wont damage the paint work... use a bit of t-cut after and then polish over it...
    Rich
    DavidR's Avatar
    Scotland
    1,295
    Auto glym tar remover does the trick too
    Apr 2003
    Birmingham
    35
    [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Apr 2003
    Birmingham
    35
    Hi
    Mate
    Myself I used auto GLYM tar removal its work on car paint like a magic so used that & its good for any mark on the car it wont damage you paint work as well. only 3.99
    Sorry rich but t cut its not good for car paint after some time its got bad effects on paint. Try this but still you have to rub hard.
    CARACTERE007's Avatar
    havin\' a giraffe
    319
    or u can just use lighter fluid!....works a treat!...ex artist used this stuff on really delicate stuff before and its been fine, did it on my a3 worked really well!...trust me its fine ...and it was only a quid! [img]/ubbthreads/images/graemlins/heart.gif[/img]
    Feb 2003
    Chester, UK
    7
    Silicone eater, for removing old sealant will remove all of the adhesive too. It is non harmful to most surfaces ie plastic cabinets etc etc.
    Joules
    A4Steve
    Thx for all the replies
    rear now de-badged, was very easy and straightforward, badges came of easily, and Autoglym tar remover took glue off with no trouble - excellent product
    looks much better [img]/ubbthreads/images/graemlins/1luvu.gif[/img]
    yaseen
    audi a4.36
    Jan 2007
    Somerset (not a farmer tho)
    11
    Two packets of floss later and the car was badgeless, although it may of been a bit cold when i did it,(2 degrees), still car looks better for it, dont think i'll be removing the rings, mite look a bit too bare. Thanks for the info.J
    InfamousAudi's Avatar
    DownShifter
    Oct 2006
    PA
    Got mine off with some fishing line wire and some good ol fashion elbow grease. I left the rings and the T sport symbol
