AH FabricationsJMB Retrofits
Results 1 to 13 of 13
    AndyC's Avatar
    Apr 2003
    Dorset
    716
    BIG belt job on my S4
    Well its that time
    next week I have to do:
    Cambelt kit inc ALL tensioners
    Alternator
    New lightweight Alloy front pulley
    Uprated Vibratechnics engine and tranny mounts
    Sparks
    Waterpump
    New Genuine coolant
    All aux tensioners and pulleys
    mod my front bumper to get better air to the I/C
    perhaps fit my oil cooler
    should be good...... :-)
    if anyone is bored and wants to come down! ;-)
    there is no such thing as bad weather, just the wrong clothes!!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,287
    You got the required cam locking bar?
    I'm about to start this on craigs S4 today. Looks like its going to piss down as well
    TD5 Land Rover Defender build
    AndyC's Avatar
    Apr 2003
    Dorset
    716
    yea got that.....going to be "fun"
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    I'm lucky enough that the previous owner did all this to mine some 1500 miles ago. I wouldn't relish the job either...
    NEW 6 cylinder 40mm front springs - £40
    PM me for more info
    AndyC's Avatar
    Apr 2003
    Dorset
    716
    in some odd twisted way i am looking forward to making sure its all correct and cleaned etc etc
    "Stick a V8 in it!"
    15,287
    Horrible job. Crank locking pin is near enough impossible to fit without dismantling half the engine.
    So i did it without.
    Used the locking bar, and a puller to remove the cam pulleys.
    It runs, MOT tomorrow
    AndyC's Avatar
    Apr 2003
    Dorset
    716
    I wasnt going to use the locking pin either.... just be careful to its correct position.
    PW-Motorsport's Avatar
    Jun 2006
    Pembrokeshire
    389
    The hole for the crank lock pin is on the right side of the block, near to the rear of the aircon pump. You need to remove the plastic blanking plug held in with a 10mm bolt. With the engine @ TDC screw in the locking tool, you may need to move the crank/engine on the dwell of TDC a little to wind in/secure the pin in place.
    With the pin in place and the cam-locking bar you can set the cam timing and tension the belt with out the bottom end moving. When setting the cam belt tension with the locking bar in place, ensure the cam pulleys are slack and turn freely. Once the belt tension is set, tighten the cam pulleys, remove both locking tools and rotate the engine two full turns. Refit the locking tools, you may have to slacken off the cam pulleys and repeat until the locking tools drop into their place with out further adjustment.
    Simples.....
    AndyC's Avatar
    Apr 2003
    Dorset
    716
    sounds identical in method to the clio 182... much better IMO
    "Stick a V8 in it!"
    15,287
    yeh, but the hole for the pin is buried down the back of the entire world.
    I'd have had to remove half the turbo pipework to get into it.
    You'll need a puller to remove the cam pulleys off the tapers.
    Do you have the ELSA manual?
    Jun 2006
    Pembrokeshire
    389
    However if you do the job for a living/correctly this is what you should do.
    "Stick a V8 in it!"
    15,287
    yep. Its probably easier on a ramp too, where you can look properly and see whats going on. Rolling around on the floor isnt nice!
    AndyC's Avatar
    Apr 2003
    Dorset
    716
    floors are over rated!!LOL
  1. Heater problem? Flaps broken, how big a job?
    By DJM1982 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 6th December 2010, 15:19
  2. Big job to replace all the rear bushes on S3
    By 1animal1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th May 2010, 11:14
  3. cam belt, timing belt ?
    By Danny Cawsey in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th May 2010, 21:10
  4. Big Turbo Big Bang...
    By S3-Dan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st March 2010, 15:08
  5. Change alternator belt at same time as cam belt???
    By Ads in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th August 2009, 11:38
