Results 1 to 10 of 10
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,870
    3" maf conversion possible alternatives ??
    Just scouring eBay and found these that look like the A4 maf sensor (position the sensor is mounted) and thought they may be another alternative to the 3" vr6 ones.
    1. 370327703070
    2. 230552272344
    It will be hard to find the Porsche one I no but a BMW one shouldn't be hard to find. That being there 3" lol
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,633
    So are these confirmed as 3" dia? as im looking to do the same....
    Currently rolling in a SKODA!!!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    The VR6 MAF's arent all that much more expensive than those?
    Der: Your car has ME7, so you need a different housing, such as TT/S3, or better still a complete TT/S3 MAF as that way you can just lift the entire MAF table from a TT map and plop it into yours.
    TD5 Land Rover Defender build
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,917
    What does fitting the 3" MAF actually do for our cars?
    Life begins at 140mph
    www.passionford.com
    May 2010
    Bedford
    2,877
    Screw it up if you`re fitting nothing else along with it lol.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    "Stick a V8 in it!"
    14,900
    The stock maf can only read to around 230hp's worth of air.
    So if your fitting a larger turbo you need a larger maf. The ECU will need remapped to suit though, as the scaling will be completely off otherwise.
    Aug 2010
    2,870
    I no the vr6 ones aren't really expensive but I just though most of them are in daily use or been crushed for scrap I just thought it may be easier to find than a vr6 I was just thinking of broadening the horizon on finding a 3" maf.
    May 2010
    Bedford
    2,877
    034 do alloy maf tubes but by the time you get one over here its probably cheaper to buy a new VR6 unit.
    Lee Goodall's Avatar
    ..got my head together!
    Oct 2007
    UK - Midlands
    2,223
    I got my 3" VR6 MAF cheap from ebay; They seem to pop up fairly often so I'd just keep an eye on it.
    Dec 2006
    131
    theres a lad on a local forum just put a vr6 maf that i sold to him on a ko3s mk4 golf 1.8t and its running 250ish bhp, using c20let injectors and mapped by r-tech
    "Rolled away with 248.292bhp at the fly and 228.707bhp at the wheels. Torque is 277.27lbft @ fly and 262.75 @ the wheels. Did run more but had to run less boost in case of the rods going!"
  1. Question regarding 3" MAF conversion
    By B5QUAT in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd August 2011, 11:19
  2. Head Lamp Conversion, Exhaust and MAF Sensor Question!
    By a3t-ian in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th January 2011, 21:57
  3. maf readings to bhp conversion
    By djdougalno1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2010, 15:19
  4. Replies: 6
    Last Post: 21st June 2008, 01:59
  5. Alternatives to the A3 3.2
    By Eeef in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th February 2008, 09:09
