Volks AutosJMB Retrofits
Results 1 to 7 of 7
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,095
    Odd water temp ???
    Took my missus to Brands Hatch yesterday and all was peachy. Doing a steady 90 round the M25 I noticed my water temp was reading 60°C. I eased right back to 50 and the temp rose again to read the normal 90°C. Wound it back up again and after a while the needle dropped back to 60°C again. Once in the 50 zone the temp stayed perfectly normal.
    Am I likely to have a problem or is the air pasing through the rad THAt cooling??
    Life begins at 140mph
    www.passionford.com
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,617
    Probably have a problem! Sounds like stat is stuck open. Mine gets upto 90 when giving it a little on the country roads but settle to 50mph and the gauge drops to 80 (Climate display says 75) I'm going to change my Stat too.
    For it not to move over 60 yesterday is very strange, surely it wasn't in the minus temp range was it outside?
    Even at 7c here, my gauge does move upto 80 under 'normal' driving.
    2002 2.5 V6 Quattro
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,095
    It only dropped to 60 when driving at speed for a period. When I left home it warmed up in the normal time to the 90°C mark and stayed there all the way to the motorway, it was still normal until I decided to press on, it was after about 10 mins at 90 I noticed the temp guage so slowed right down to 50ish and after a while the gauge returned to normal. I pressed on a second time and the same thing happened.
    On my return journey I wasn't in a rush and came back at a steady 70-80 and the gauge was perfectly normal and stayed at the 90°C mark.
    www.passionford.com
    S4_dan's Avatar
    Jan 2006
    1,617
    Still sounds like the stat, could be sticking open occasionally. Can't see the outside temp been able to cool the system that much unless it's in the minus temps.
    2002 2.5 V6 Quattro
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,530
    stat
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,388
    Yep stat.
    Buy a good one though, mines only a month old and is already acting up.
    TD5 Land Rover Defender build
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,095
    Have a genuine VAG thermostat in my spares bin so will have to have a looksie at that when I get back from holiday
    www.passionford.com
  1. Intermittent Cooling fans, odd temp showing below 90
    By Dubstep in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th July 2011, 19:28
  2. temp gauge acted a bit odd
    By deanski in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th January 2011, 13:11
  3. water temp
    By mkh1357 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 14th August 2009, 11:36
  4. Odd place for a water leak
    By H2o-uk in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th January 2009, 17:16
  5. Water Temp on A6 V6 2.6?
    By skippy in forum Classic Audi Forum
    Last Post: 21st April 2005, 07:46
