Chris NottVolks Autos
    Mar 2011
    9
    Exhaust on a 2000 2.8 Quattro
    Does anyone know if the exhaust on this car is one piece from the cats back?
    I need to change the centre silencer only but was told that the whole system is one part (£360!)
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,504
    I have a 98 2.8 and the exhaust from the cats is in one piece. I'm not sure if this has been welded or not as I was also under the assumption that the rear silencer and middle silencer split. But maybe its not the case??
    2002 2.5 V6 Quattro
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    Audi sell the system as two parts, and supply a joiner. The stock system is one piece though.
    That said, the centre box alone is ~400 from Audi.
    TD5 Land Rover Defender build
    jamie226bhp's Avatar
    Aug 2009
    456
    I've got an rs4 centre silencer you could have but you'd need to make it fit ax I cut the rear bix off for mine but I'm based in dartford or remove it and put a straight through pipe in instead
    2000 A4 1.8 tqs scroll sp51, ths decat, milltek cat back with rs4 backbox, remap
    S4_dan's Avatar
    Jan 2006
    1,504
    That will explain my one piece the and its condition then. 170K, 13yrs old and only a bit of corrosion on the middle box! The rest of the system is in very good condition!
    2002 2.5 V6 Quattro
    Aug 2009
    Dorset, UK
    171
    I have a 2,8 Q year 2000 w reg, took off the original standard exhaust, it was two piece from the cats back & fitted a Miltek 3" system which was a Three piece system - 1st) the two into one section (from the two Cats to the one 3" pipe) 2nd) the center box - 3rd) the rear box.
  1. Whats the best exhaust for me to get for my s3 (2000)
    By Rogue-24-84 in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st December 2011, 17:30
  2. exhaust drone a 2000 revs - 1.9 tdi
    By technics100 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th November 2010, 13:05
  3. 2000 A6 2.7T exhaust
    By phantomA6 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 14th July 2004, 03:43
