Volks AutosChris Nott
Page 5 of 5 FirstFirst 12345
Results 161 to 170 of 170
Like Tree6Likes
Thread: A small project
  1. #161
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,656
    Quote Originally Posted by jbh View Post
    could you not just connect a test meter up to one of the glow plugs when the engines cold and then turn the ignition on and see if there is power going to them? earth it off the body and the live to the glow plug
    Did not think of that.
    I'll do that.
    Quote Originally Posted by Arrkon View Post
    Or stick a 5w bulb between the bolt (terminal) end of the plug, and the body ground
    Sod that. I'll get my metre out.
    so Scott when are you going to start making up wiring adapters for this?
    never.
    I'll help people out but making looms is a right pain in the ass.
    I'm not sure many people would really want to spend the extra time and effort fitting facelift clocks cause of the oil sensor?
    A4 B5 Double Din, RNS-d, TMC, Full Sports Leather Heated with Leather Door Cards and Lower Door trims all for sale.
    Audrey's Build Thread
    RIP Audrey. She's being broken down.
    New Car, New Thread.
    Scott's Akoya Silver A8
  3. #162
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,656
    Massive thanks to @udiA3 for sorting out my miles.
    They are now reading correctly.
    I was unable to do this with vagtacho or vagcommander but he did it first time, no errors.
    See him if you want your car clocking.
    But really don't, its illegal and people gets in to trouble, so only do it when you swap clocks.
    To finish this little project off I need to fix my DIS screen and tidy up the wires at the back.
    Due to weather getting crap and winter really setting in, the wires will have to wait till next year.
    Might be worth moving on to the next little project
  4. #163
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,877
    And what might that little project be !!!!
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
  5. #164
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,656
    Quote Originally Posted by Bradderz_1988 View Post
    Check my other thread.
  6. #165
    May 2012
    RETFORD, NOTTS
    1,712
    Quote Originally Posted by ScottB5 View Post
    Grey area, use to be legal to do it, but not with the intent to gain money from making the car appear of more value etc. I have read a few people being prosecuted now though for doing the clocking not only the tradesmen that sell the motors.
    Cheap vagtacho = fail :D
    ScottD3 likes this.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
  7. #166
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,914
    Must be something wrong with scotts cheap vagtacho, as it wouldnt read the SKC either. Mine read the SKC and altered the mileage just fine on an immo3 cluster.
    TD5 Land Rover Defender build
  8. #167
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,656
    It works on other just not this cluster.
    Byzan had the same issue.
    Not authorized was the error.
  9. #168
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,656
    Not much happening this at the moment.
    Mainly just testing it and planning my next move to wire up all the doors, boot, bonnet, clean the wiring up behind clocks, removing the converter cable and fitting a new DIS screen.
    @udiA3 sorted out my miles at ADI, so that's all done.
    It is just sit back and enjoy this view for now
    I might make the adapter looms but they are a bit of a pain cause I need PFL clocks to take the plugs from and FL loom with plugs and several inches of loom, more cable the better for you.
    It takes me a whole day to make the loom, so it wont be something I'll do for free on the odd free weekday I get, it will be a saturday or sunday when I got the whole day free, so it can take me some time to do it.
    I might talk to Kufatec and some others and see if they are interested in it.
  10. #169
    AVLO's Avatar
    Mar 2012
    Doncaster
    255
    Hi Scott I'm going to be getting a B5 S4 a week tomorrow and it currently has the anologue clocks in it, would it still need a loom making up to be able to use digital clocks from a facelift S4?
    Matt
    BRING ON THE WET WEATHER ​QUATTRO FTW
  11. #170
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,656
    Hi Matt,
    You'll need a oil level sensor in your sump and a loom.
    The looms are a bit of a pain cause you have to distroy a set of clocks to make, that's if you want to it reversible and plug 'n play.
    The main stopping point for people is fitting a oil level sensor, without that its going to be an annoying cluster swap.
  1. Would these wheels look right on my a3 or are they to small?
    By braque10 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st May 2011, 02:17
  2. Is the A4 to small?
    By reggieroo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th September 2010, 11:10
  3. my New A4 Project "Project Dogs Dinner"
    By Drifterwanab in forum The Project Room
    Last Post: 15th August 2010, 18:43
  4. A small tweek
    By Oranoco in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd March 2009, 20:12
  5. Would these bolts be too small?
    By Defratos in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th October 2006, 17:34
