Glad I could be of assistance
Thanks for that mate.
Been out today and got the key coded to the clocks so it now starts and runs.
The wires are still a mess but it will do until I worked out the niggles.
I assumed the oil sensor was working fine cause I never got any errors but the errors only appeared when I started the car, which I could not do yesterday cause I was unable to start it. ******.
What are the niggles at the moment.
Revs counter don't work and it throws up a error about oil level.
Starts off ok, all looking good.
Then this little ******* pops up
Got oil and sensor is in correctly.
I thought it might have been my wiring of the oil level sensor but that appears ok going by the logs.
With the oil sensor unplugged or power removed I get one or both of these errors.
01311 - Information Data Bus
37-10 - Faulty - Intermittent
00562 - Sensor for Oil Level/Temperature (G266)
30-00 - Open or Short to Plus
With it plugged in and connected I get nothing. So I think its wired in correctly.
Talking to Byzan he said it could be the fact that I got no revs its causing the error.
The other error I'm getting is this
01314 - Engine Control Module
49-00 - No Communications
That might be the cause of the revs not working, which in turn might be the reason for the oil error I'm getting.
WIth the help of @udi A4 we tried coding my other keys but none of them worked. I got a random selection of keys in different states and condition. We think its cause all the keys have been coded before and wont code to the clocks.
In a last ditch effort to make sure I'm doing it right and the clocks work, we tried to code my main key with the clocks. It worked!! Brilliant.
Or not cause I forgot to tell @udi A3 that I don't have the SKC code for my old clocks and as such I can't recode the key to my old clocks.
So I'm kind of stuck now with semi working facelift clocks, which is ok as long the oil level sensor don't keep beeping at me.
@udi A3 can get SKC codes and code clocks, so he offered to come down and help me out but its about a 7 hour trip to get here for him, so I told him to stay home and if I get really stuck I'll meet him half way.
Thats my current even and state of affair with my clocks.
I've not attempted the RNS-d wiring yet. I want to get the clocks working.
Has anyone got any idea what I need to do to get the rev counter working?
New ECU?
Extra cables?
I looked in to what LeeT said about canbus being in the current ECU already but I can't find anything on the pin outs in ELSA.
I'm stuck and at a dead end I think.
HELP!!!!
