Badger5EM Tuning
    gaz71's Avatar
    1.8T Quattro Sport AJL
    Jul 2009
    Torbay
    287
    Can anyone identify this?
    Hi,
    I was changing the air filter in my TQS and had to move the usual assortment of pipes, wires and hoses out of the way.
    I undid the clip holding this component only to find that it has at some point broken off inside the hose.
    Can anyone tell me what this part is, what it does and most importantly if they have one knocking around in their garage as I am sure that it will be expensive at the local stealers (I can hear the sound of sweaty palms rubbing together already !)
    Here is the part,
    Thanking you all in advance,
    G
    To date - 2.5" Jetex exhaust, Generic re-map, Silicone hoses, N75k, shiny 17's, FK Springs
    Wanted - Sports cat, bigger downpipe, FMIC, Bigger turbo
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,134
    It's a check valve (one way) for the fuel tank vapours that are drawn to the intake
    gaz71's Avatar
    Jul 2009
    Torbay
    287
    Quote Originally Posted by Bradderz_1988 View Post
    So nothing drastically important. Managed to fit it back into hose and clamp it up.
    Aug 2010
    3,134
    I did same with the n80 valve that's further down that pipe on the airbox price one up from audi it was iirc around £75 so I did what I could with it and had no problems get a bit of a wiff of fuel sometimes as I don't think it's very air tight just going to try and get one next time I'm at the scrappers that's if it doesn't break again as it will probably be the same as my old one or even worse lol
  1. Help me identify these wheels please!
    By impster in forum Handling
    Last Post: 20th September 2011, 20:38
  2. TDi Quattro...170...how do you identify them?!
    By Cossie_boy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th November 2009, 23:40
  3. Can you help identify these wheels please?
    By impster in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th July 2009, 11:32
  4. can anybody identify these wheels
    By nickstevens in forum Handling
    Last Post: 27th February 2007, 10:31
  5. Anybody please help me identify this?
    By Nessy in forum Classic Audi Forum
    Last Post: 3rd January 2007, 20:44
