Badger5JMB Retrofits
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,572
    How weird is this DTC??
    Cleaned and refitted my original TB (part number doesn't match to what ETKA states should be on my car, but it came with this TB fitted and obviously been opened before!)
    Drove the car to get some fuel tonight after doing the TBA hours earlier. Car doesn't have as much power as it did with the replacement TB on (That was noticeable straight away fitting the new one, but it caused it me running problems)
    Anyway, came home fan blowers not working so decided to scan the car. Anyway, the SECOND DTC has me worried!!
    These are the results:
    VCDS-Lite Version: Release 1.0
    Sunday, 09 October 2011, 17:47:11:0
    Control Module Part Number: 4D0 907 551 F
    Component and/or Version: 2.8L V6/5V MOTR HS D03
    Software Coding: 04201
    Work Shop Code: WSC 00020
    4 Faults Found:
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 -- 35-10 - - - Intermittent
    17968 - Maximum Engine Speed Exceeded: Engine Warranty VOID! :-)
    P1560 -- 35-10 - - - Intermittent
    16551 - Oxygen (Lambda) Sensor B2 S3; Heating Circuit: Malfunction
    P0167 -- 35-00 - -
    01169 - Door Contact Switch Driver Side (F2)
    11-10 -- Control Limit Not Reached - Intermittent
    Not that there will be any warranty on the engine anyway, but is this caused by hitting the rev limiter? I took the revs right round in 3rd but don't believe it hit the limiter?!?
    Dan
    2002 2.5 V6 Quattro
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,324
    Rev limiter wouldnt cause that imo.
    It means the engines been revved past the limiter, for example downshifting from 4th to 3rd or whatever.
    TD5 Land Rover Defender build
    jamie226bhp's Avatar
    Aug 2009
    464
    I had that engine speed exceeded on a Puegoet and it was a sensor on the gearbox that had broken up inside
    2000 A4 1.8 tqs scroll sp51, ths decat, milltek cat back with rs4 backbox, remap
    S4_dan's Avatar
    Jan 2006
    1,572
    I've read online after posting, that its possibly caused by the cam sensor?!
    Very strange.
    Still have that bloody B2 S3 fault code though?!?!
    But no TB Basic Settings DTC!! whoop whoop. lol
    2002 2.5 V6 Quattro
  1. Weird one, this!
    By Ads in forum Forum Support
    Last Post: 8th August 2011, 20:50
  2. Weird???
    By lifeboatcrew in forum VCDS (formerly VAG-COM) forum
    Last Post: 17th July 2010, 12:17
  3. How weird, don't know what to do?
    By boostboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th December 2009, 11:20
  4. weird gimmick???
    By gixxer600k4 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th July 2009, 10:53
  5. Another weird A3
    By rickparmar in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st January 2006, 01:58
