EM TuningBadger5
Results 1 to 14 of 14
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,566
    URGENT....Fan blower stopped working out of the blue!!
    Refitted my old throttle body after a good clean today and now my fan motor for the windscreen has stopped working.
    I use my car at 5am for work. Really need help on this guys please.
    I've checked all of the fuses (cos i didn't know which is fan but found it to be fuse 25?), All fuses are ok.
    Cheers,
    Dan
    2002 2.5 V6 Quattro
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,106
    Blower motor will be shot more than likely.
    S4_dan's Avatar
    Jan 2006
    1,566
    All of a sudden? Seems strange that it was coming on earlier when i was doing the throttle body alignment though? Then left the car for a few hours, just been for some fuel and noticed no fans. Climate display still shows fan bars on the side.
    How do i access the blower motor?
    Dan
    2002 2.5 V6 Quattro
    Aug 2010
    3,106
    Remove the glove box and then try put a direct 12v feed to the fan.
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,071
    Piece of piss to change mate, I did mine in the office car park over lunch. Much to the bemusement of my co workers lol.
    Gen fan from ECP was about £70 iirc
    Life begins at 140mph
    www.passionford.com
    S4_dan's Avatar
    Jan 2006
    1,566
    THinking of going to a scrappy on tuesday aft to pick one up. But will do some checks tomorrow eveing, too dark now.
    Cheers for info Oranoco.
    Dan
    2002 2.5 V6 Quattro
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Bit of a pointer,
    Mines stopped twice now also, was told it would be the motor but as u say its strange that it would just stop and not be intermittently at fault for a period first. I got into mine to find the live connection rubber sheath had melted and lost connection. Cleaned it up and worked fine. This only happened after jump starting the car thou, but worth checking before buying a motor or replacing brushes.
    Project RS28 build
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,500
    Brushes are gone, i got some and soldered thenm into mine veofr it expired, cost me a fiver and half hour to remove, solder and refit. Sorted.
    Jun 2003
    World of my own
    9,813
    £40 delivered for a brand new OEM Valeo unit on ebay. This is a maintenance part so getting one from a scrappy is pointless as it will have the same issue eventually.
    Alex Turner
    S4_dan's Avatar
    Jan 2006
    1,566
    Removed fan after work and it spun freely by hand. Plugged back in and turned fan on. felt it 'hummm' but no movement. so quick spin by hand and its off, spinning away, with a repetitive 'clunk' noise when spinning. Turned it off and back on but wouldn't spin on its own accord.
    How do i remove the motor from the housing?
    There does seem to be some corrosion in there, and some of the holding screws were a bit rusty too!
    Dan
    2002 2.5 V6 Quattro
    S4_dan's Avatar
    Jan 2006
    1,566
    Found it very easy to remove motor. removed brushes and there is about 1cm on both sides left. lights sand on those as they were dirty, and a quick clean at base of motor where they contact. Too late now to go outside and refit and try but will plug it in in the morning as i will prob need the fan in the morning!!
    Dan
    2002 2.5 V6 Quattro
    Jul 2007
    London
    3,206
    Get a new, genuine one mate, i did try new brushes and after a lot of messing about i just gave up. It's the windings inside the motor, one is shorted. I have even tried making a good one out of 2 broken ones with new brushes, worked for just a week ! I don't waste my time anymore especially for the sake of 70 quid. Dealer's price is over 225 pounds !
    FOR SALE:
    S4_dan's Avatar
    Jan 2006
    1,566
    Well, fitted it back in this morning at 05:45hrs and all is sweet now! No rattling and getting nice flow of air again. Will keep an eye on it and the scrappy have several in so if i need one urgently one of those will tie me over until i get a new one. But fingers crossed, it's sorted for the time being. :-)
    Cheers for everyones input.
    Dan
    2002 2.5 V6 Quattro
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    579
    Deffo sounds like the brushes so I wouldn't hold your breath on it working for long. It really is an easy job to change the brushes and you can get them off ebay for about a fiver
    2000 1.8t quattro Sport totally standard (ish)
  1. Replies: 3
    Last Post: 12th February 2011, 09:56
  2. AC/Heat blower fan stopped working
    By LWNY in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th February 2011, 17:33
  3. Blower working but no air through vents - intermittent
    By bluemoon39 in forum Air Conditioning
    Last Post: 20th August 2010, 14:25
  4. Key Fob Just Stopped Working Lock/Unlock not working
    By tomgreen78 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th March 2010, 23:53
  5. Heater Blower not working - help
    By nickf in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 28th November 2009, 20:06
