EM TuningBadger5
    jcb
    Sep 2005
    uk
    4,077
    quick question on flywheels
    if the 1.8tqs has a 210mm clutch and the S3 has a 240mm clutch and the S4 has a 240mm clutch.....
    why cant 1.8t owners looking to use an S4 clutch use an S3 flywheel and an S4 clutch?
    is the BAM engine (S3/TT) crank bolt pattern the same as other 1.8t's?
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,133
    The 1.8t A4 uses a 228mm clutch iirc, and the flywheels on tranverse are differant I think either crank bolt pattern or starter ring aragorn will now more on this subject lol
    Also A4's and S3's use dual mass flywheels and S4's have a solid flywheel so the friction plate has a sprung hub where as a dual mass doesn't.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,346
    The transverse boxes use a different input shaft spline to the longitudinal ones, and the geometry of the starter ring is different as is the overall "height" of the flywheel/clutch pack. The starter attaches the other way round on a transverse engine, with the motor body alongside the transmission rather than the engine.
    They're also dual mass, and jsut as expensive new as a ECS or TTV conversion item, and i'm not sure i'd be wanting to fit a used dm flywheel to my engine.
    The crank itself is the same.
    TD5 Land Rover Defender build
    jcb
    Sep 2005
    uk
    4,077
    so my TTV flywheel 240mm won't fit an S3 then!
    damn, thought I had a buyer
  1. Quick question quick reply needed !!
    By Bradderz_1988 in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd September 2011, 10:51
  2. QUICK QUESTION...QUICK ANSWER NEEDED!
    By vw754 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st April 2009, 16:33
  3. Quick question that needs a quick answer!
    By ScottSummerhayes in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th February 2009, 16:12
  4. A question to the floor - clutches & flywheels
    By jcs356 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th March 2008, 20:19
  5. Question: Dual mass flywheels
    By warren_S5 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th February 2008, 12:17
