Oilfilter tool?
I use water pump pliers or my hands but on my car I use a spanner as I've one of those k&n wrentch off's fitted.
^^^ yes there a good tool aswel don't have one personally but have used them in the past and they are better than chain straps.
I use a Laser oil filter tool from local halfords, the best i've worked with and it's handy when replaceing pullys as well.
This is the one I used it got the most votes in a survey when I looked for one at the time..
It's all about getting in to turn the Filter with your hand..
I always undo the water top up reservoir and move it to one side so you can access the oil filter better..
I only used this because some Mechanic over tightened it..
When you Screw in your new Filter use a pair of Gloves to tighten the Filter Hand tight then you will never need a Wrench again you should be able to unscrew again with gloves on..
No need for a Wrench should only be done up hand tight anyhow..
DRAPER 10784 OIL FILTER WRENCH 100MM CAPACITY | eBay
545
10
2K
6
