Badger5Monster Motorsport
    Jun 2011
    Audi a4 2000 dash computer bulbs or LCD? , need some advice
    Hi iv just bought a a4 tdi 2000. It's the se so has a full display with engine check at top( orange) when the door is open the main computer lights up and shows which door is open but once the door is shut it goes black. Almost like it switches off. So I cant see mpg , trip distance ect. It only illuminates when the door is open. I know these are prone for failing but I'm lead to believe that's it's due to dead pixels normally , well the pixels are 100 % on this. When it lights up all the pixels are fine. Am I right in thinking there is a small bulb that could be at fault?
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,115
    On the bottom of the wiper stalk these a reset button press this as you can switch it on and off from there if it's failed then you will have to remove your clocks and send it away to be repaired.
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,078
    As above mate try turning the display on using the reset button under the wiper stalk
    Life begins at 140mph
    www.passionford.com
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,324
    i concur. Its simply switched off.
    If it was broken it wouldnt be able to show the door or fuel warnings.
    TD5 Land Rover Defender build
    Jun 2011
    Omg I can't believe how stupid I was. You boys were correct. Haha cheers for your help. So glad it doesn't need replacing
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,078
    You aren't the first and won't be the last, at least you know now
    www.passionford.com
  1. Audi A3 dash vent advice
    By rusko007 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th November 2011, 23:04
  2. Dash bulbs
    By fARQUARE in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th November 2010, 16:01
  3. Dash computer symbols
    By Luckymonkey in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th April 2007, 22:23
  4. Dash Board Computer?
    By S3MCS in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd February 2007, 13:33
  5. Dash Bulbs?
    By rsvrdave in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th March 2006, 21:41
