Chris NottEM Tuning
Results 1 to 8 of 8
    Jun 2010
    76
    FRONT DOORS DROPPING
    I think I read on here before the best method of fixing the front doors dropping was to open them and jack them up with a trolley jack? Any other methods??
    Oct 2011
    I also need to know whats the best way to sort this, both my front doors have dropped about 10mm
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,031
    the jack methods or the 13mm socket in the hinge and shut the door. or remove the inner trims and adjust the door on the bolts.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    AndyC's Avatar
    Apr 2003
    Dorset
    717
    same problem....
    i he-man'd one door and it made it a little better
    there is no such thing as bad weather, just the wrong clothes!!
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,031
    both my front doors dropped.
    I replaced the hinges one side and adjusted the other side.
    both worked, don't agree with the socket or jack method though.
    Oct 2011
    Quote Originally Posted by scott b5 View Post
    Could you give a quick run down on how to adjust them thanks
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,650
    mine has (drivers side) dropped too, whats this 13mm socket all about??
    Currently rolling in a SKODA!!!
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,031
    to adjust the doors you need to find the bolts for the hinges inside the car. behind the kick panel and behind dash.
    the 13mm socket way, I think is put a 13mm socket in the hinge and shut hte door.
    I think thats it. Bend the hinge/door for it to fit.
  1. Rust on bottom of front doors :(
    By V6Pete in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th March 2012, 15:53
  2. front doors sticking :s
    By bigblokey0 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 9th June 2010, 22:42
  3. Will DLS R5A 13.5 Speakers Fit in the front Doors A3 8l?
    By dot32 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th April 2010, 14:19
  4. 6 inch components in front doors
    By marty.blake7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th June 2009, 09:01
  5. Anyone fitted 5.25" Speakers in front doors?
    By AndyCollins in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th March 2006, 19:21
