Badger5Volks Autos
Results 1 to 7 of 7
Thread: C.V boot
    skinz's Avatar
    May 2011
    leicester, uk
    233
    C.V boot
    i need to change the C.V boot but having trouble removing the C.V joint, on my calibra you had to give it a good hit with a hammer making sure you didnt pull the driveshaft out of the gear box, is it the same on the A4's, any tips would help loads cheers
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    yeh, its the same.
    Alternatively you can screw the bolt back in thru the middle of the joint and use that to push the CV off.
    TD5 Land Rover Defender build
    skinz's Avatar
    May 2011
    leicester, uk
    233
    sweet didnt think of that cheers bud
    May 2010
    Val d'Isere
    85
    yeh, its the same.
    Winding the old bolt back works a treat pulling the CV off. Just be careful of shrapnel coming off the bolt threads and ending up in the joint. It may not happen to you but just a heads up before it gets in your joint.
    2,159
    On my facelift B5, the bolt trick does not work as the drive shaft appears to be hollow at the end all it did to the bolt was to damage the thread, which made it difficult to get the bolt back out. In the end I pushed a smaller bolt through and used the drive shaft bolt to press on the smaller bolt. Was thinking about making up the tool below all you would need is a bolt which is about double the lenth of the standard one and a grinder to shape the end of the bolt.
    May 2010
    Val d'Isere
    85
    Sounds perfect. Like a crank extractor on a push-bike.
    The hollow end of the drive shaft must have been what caused the shrapnel in mine.
    skinz's Avatar
    May 2011
    leicester, uk
    233
    the bolt thing worked a treat, they should do this on all cars made it so easy to do, that was a top tip, there such a ball ache trying to hit of with out doin any damage or pulling the drive shaft out and with the audi having all that extra metal work behind the wheel makes it much harder to swing a hammer in there
  1. Water pouring in boot when boot opened.
    By bengal in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th October 2010, 10:29
  2. Boot sill protector and recommendations for boot liner
    By markphelan in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 15th May 2010, 18:46
  3. boot lid
    By gixxer600k4 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th May 2009, 13:30
  4. CV DSG boot
    By SteveTDCi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th April 2009, 16:23
  5. CV Boot
    By ukmayhem in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd July 2006, 22:02
