Sky InsuranceEM Tuning
    symun's Avatar
    Jun 2011
    Swansea
    147
    Coolant flange....
    The one with the temp sender attatched, went to replace mine earlier and i stopped short of starting as soon as i saw the hose clips.
    How are they undone, are they just squeezed with a big pliers.
    Not an emergency as i only leeks a trickle but i would like to do it tomorrow........
    Blanked off the egr instead.....jesus that was effing dirty......
    As soon as i have time the intercooler and hoses are coming off for a good swill........
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,373
    Which hose clips?
    You can undo the constant tension clamps with a pair of water pump pliers, but it can be fiddly.
    Depending on the age you may also have a push fit feed for the heater matrix, these require you to pull up the metal spring, then the hose will pull off with some wiggling.
    TD5 Land Rover Defender build
    symun's Avatar
    Jun 2011
    Swansea
    147
    Ok cheers.......
  1. Anyone got a picture of there flange,,lol
    By Kelza in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th September 2011, 00:13
  2. 1.8T Exhaust Flange CAD file
    By IN 2 Deep in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd January 2011, 21:22
  3. ko3 downpipe flange dimensions
    By Robbo1144 in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th October 2010, 16:25
  4. Coolant temp. sender flange leaking, why?
    By 2.0 8v in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd July 2010, 22:25
  5. Attempted Coolant Flange - Arse!!!!
    By evilscotsman in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd March 2009, 09:55
