    Jun 2010
    76
    AFN into facelift?
    Would a AFN 110 from a '97 model be a straight replacement into a '99 facelift? (not sure of engine code) Or would the loom/ECU need swapped aswell?
    Jun 2010
    76
    Or would the older ECU/loom not be compatable with the facelift dash??
    Jul 2007
    London
    3,076
    The facelift was available with AFN engine and also with derivatives of the engine: AVG - 110Bhp, AHU- 90 Bhp with a wastegated turbo and AHH 90 Bhp with a VNT turbo and 11mm pump as standard. Is yours a VE engine ? If yes then the engine will work with the wiring loom you allready have. The early AFN had a steel sump the later had a alloy sump with provision for the oil sensor level. That's pretty much all the difference really. Look at the ecu plugs, early ones had a 82 pin ECU, later had a 122 pin ECU wich is flashable trough the OBD port. Minor difference are the injector plug wiring, 110bhp had a 8 pin plug connector, 90 Bhp had a 10 pin connector but they are easy to swap around.
    FOR SALE:
  1. Facelift of Facelift: They've now changed the dash components on me
    By ambanmba in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th August 2012, 14:28
  2. Replies: 3
    Last Post: 12th August 2009, 10:42
  3. How easy is it to fit a facelift centre console in a pre-facelift?
    By Blue_Thunder in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th August 2007, 13:09
  4. Facelift head lamp guys on pre facelift cars.
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th December 2005, 18:58
  5. Fitting facelift A3/S3 headlights to a pre facelift 1998 A3
    By BromleyA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2005, 20:10
