Volks AutosChris Nott
    Jul 2011
    21
    Avant Tailgate Removal
    My Avant has a had a shunt up the rear and now needs a rear bumper and tailgate. Its a 1997 1.9tdi quattro.
    Do we have a guide on here explaining how to remove the tailgate and all the gubbins inside? I've done a quick search but not come up with anything. Is it a fairly straightforward job?
    Also does anybody have a rear bumper and ail gate available?
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,645
    PM TonyA, he's breaking an avant and I think he has all the bits you need.
    A4 B5 Double Din, RNS-d, TMC, Full Sports Leather Heated with Leather Door Cards and Lower Door trims all for sale.
    Audrey's Build Thread
    RIP Audrey. She's being broken down.
    New Car, New Thread.
    Scott's Akoya Silver A8
    Jul 2011
    21
    Cheers Scott!
    May 2010
    Val d'Isere
    85
    Quote Originally Posted by scott b5 View Post
    Just watch the year it comes off. I have just had the same problem (and 3 lids later became sort of an expert in Avant tailgates!)
    As far as I know >'97 is part number 8D9 827 023D. Same number ending in 'S' is '98 and early '99 (different slam panel) and late '99 onwards ends in 'R' (facelift solenoid mechanism).
    I was going to try and fit the facelift but gave up as the CL pump and loom isn't a direct swap.
    Incidentally if anyone needs a Nogaro blue facelift Avant tailgate with tinted glass PM me!
    Jul 2011
    21
    Thanks mixmaster, you probably just saved me lots of annoyance!
    May 2010
    Val d'Isere
    85
    No worries.
    The tailgate is really easy to strip. Just be patient pulling any fasteners so as not to break them. With the CL mechanism don't cut the pipe - squeeze the 'clip' where the hose attaches to the vacuum servo and it clips off (I also found this out the hard way).
    Once unclipped feed the wiring loom out one side and the CL hose/rear washer hose out the other. Once out you can remove the tailgate.
    Careful taking out the external operating handles (above the number plate) - they need squeezing from the inside first or you will break them.
    Take a couple of pictures as you go so you can put it all back the same way!
    Anywhere near Leicester and I am happy to help. PM me if you get stuck.
  1. RS4/S4 Avant B5 Tailgate with Spoiler
    By Drizz in forum For Sale/Wanted - Audi Parts
    Last Post: 15th May 2011, 14:50
  2. S4 B5 Avant Tailgate Solenoid problems????
    By s4best4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th January 2010, 19:01
  3. Avant Tailgate Trim
    By motosparkz in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th April 2008, 22:57
  4. Removal of light unit located on Avant tailgate panel
    By judge888 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 29th September 2005, 20:49
  5. How heavy is an a6 avant tailgate?
    By installer69 in forum General Chat
    Last Post: 6th December 2004, 17:11
