AH FabricationsEM Tuning
Thread: Cruise
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,641
    Cruise
    Can anyone give me a wiring diagram (from bentley manual or similar) that shows the Cruise control arm plug and the white ecu box connector? want to have a crack at building a loom for my imminent cruise control, rather than buying one from kufatek.
    or even just a list of what colour wire goes from what pin to what pin.....
    cheers all.
    Currently rolling in a SKODA!!!
    Jan 2011
    Aberdeenshire
    646
    I did a guide a while back, that might help with the white plug end, although I don't think you can make out the stalk end.
    A4 B5 Cruise Control Retrofit Instructions with pictures
    I'm also sure Aragorn posted a wiring diagram at some point, but I can't find it. It really might be more hassle than it was worth as I was only £27 delivered from the Germans.
    (I am, of course, assuming you're DBW!)
    I did find this http://homepage.ntlworld.com/c.caldo...liftcruise.pdf link to a diagram
    1999 A4 B5 1.9 TDi FWD Saloon, Green SOLD
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine - and gearbox )
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    2006 A6 Allroad 3.0 TDi Blue, awaiting stuff to be done!
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    I used PaulF's write up for mine.
    NEW 6 cylinder 40mm front springs - £40
    PM me for more info
    Arrkon's Avatar
    Oct 2010
    1,641
    paulF, you sir are a gentleman and a scholar. just what i needed
  1. cruise control
    By Jama665 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th April 2011, 09:45
  2. cruise and dis
    By swarcup in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th June 2010, 13:24
  3. Cruise Control 8p0 054 692 A
    By edition in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th November 2009, 16:39
  4. Cruise/DIS B7
    By slinedab in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th March 2009, 20:35
  5. Cruise
    By jdp1962 in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th July 2005, 08:34
