Chris NottVolks Autos
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,503
    Uh oh, just found a broken hose....
    Whilst trying to see what number is on my throttle body, i've uncovered a broken pipe, in two places. The pipe is the breather pipe and it's broken/snapped the at the rear of bank two and also at the front of bank two (passenger side cylinder head).
    What problems (if any) does this broken breather pipe pose? As a temp measure could I try and tape it up until i'm able to do a better fix or replace the pipe?
    Dan
    2002 2.5 V6 Quattro
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,866
    It will probably idle high and run like pants as the air its drawing in isn't metered.
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    S4_dan's Avatar
    Jan 2006
    1,503
    Idle is fine or very low, depending on how the MAF, Lambdas etc behave. never had high idle problems.
    If it's a breather, does that feed back into the air intake or throttle body then?
    2002 2.5 V6 Quattro
    Aug 2010
    2,866
    Yes it should but it should only vent crankcase vapours if it's split then it may be drawing unwanted air so it's getting more air than what the MAF is reading.
  1. Electric Window Broken (not broken clips though)
    By SyA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th March 2013, 11:23
  2. Broken Hose Question
    By Ruin20 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th August 2010, 22:26
  3. Found a split hose!!!
    By Y83OLK in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th March 2010, 20:18
  4. Charcoal Filter - Broken vacuum hose
    By nershen in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th May 2007, 20:13
  5. help! broken hose and totaly clueless!
    By CJA318T in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th April 2007, 13:59
