Chris NottVolks Autos
Results 1 to 10 of 10
    Aug 2011
    16
    Another problem...This time the clutch
    THe clutch has felt fine since I bought the car. No slips or judders or anything. Then today I did my usual (started car by holding clutch in) and the engine and car shook violently. I switched the engine off and took my foot off the clutch pedal but the pedal stayed down.
    With a little gentle help it came back up. Switched the engine on and it ran fine. Went to select gear (gear shift feels fine, no crunching) but the gear does not engage.
    Need advice as im kind of thinking a broken cylinder (hopefully cheap fix), but if its a new clutch then may as well scrap the car
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,287
    Sounds more serious than the slave to me.
    If you can select the gear but it wont move it suggests something wrong with the clutch driven plate.
    What engine is it?
    TD5 Land Rover Defender build
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,106
    Seen this sort of fault before the pressure plate may have snapped a retaining spring or fork spring so it's not fully engaging/disengaging the clutch.
    Aug 2011
    16
    Its an AFN engine. Ive done some investigating. Its not the slave but that was on way out so replaced anyway. Not master (looks quite recent and found to be working fine. So bradderz looks like what your saying could be the fault
    Aug 2011
    16
    Can select any gear with or without using clutch - makes no difference. Had front wheel in air, put in gear and moved one wheel by hand and the other doesnt move.  So sounds more like a plate to me but Im no mechanical god so only a guess. Comments appreciated
    Aug 2010
    3,106
    I'd say you're guna have to whip the gear box out if it does it in all gears the I'd inspect the clutch closely, if it's a certain gear ie 1-2 3-4 then it may be a syncro at fault.
    Aug 2011
    16
    It does the wheel thing in all gears bradders. Gearbox off soon then!
    Aug 2010
    3,106
    Have you tried listening to the tone and feeling of the engine at idle then engage the clutch To see if it changes tone quite abit or any feel of vibration through the gearstick/pedal/car ??
    "Stick a V8 in it!"
    15,287
    the fact he can select any gear with the engine running and without the car taking off down the road is a pretty good indication that the clutch itself is fubar!
    Aug 2011
    16
    TURNS OUT THE CLUTCH PLATE HAD BECOME TWELVE PIECES! Got it fixed and the car sold. Good riddence
  1. Time for new clutch
    By womble7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th July 2010, 20:35
  2. Its time for a new clutch...
    By J7USS in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th February 2010, 12:09
  3. Workshop time to fit a clutch
    By Scottynic in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th October 2009, 18:58
  4. New clutch time!!
    By themanthatcan in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th June 2008, 22:10
  5. Time to get a new clutch or?
    By ForthRightAfter in forum General Technical / How To
    Last Post: 17th November 2007, 14:42
