Volks AutosBadger5
Results 1 to 9 of 9
    Biodiesel Purrrr
    Jun 2011
    London
    150
    A4 Avant '98 - facelift / flat wipers?
    Hi all,
    time for a little upgrade as Autumn draws ever closer...
    I want to get new-look / flat wipers on the Avant but with the new wiper arms too rather than a conversion kit for the '98 wiper arms -
    is this possible?
    if so - what year / model Audi would I need the bits from?
    thanks in advance,
    P)
    TDi Biodiesel sippin' A4 Avant - EGR blanked
    "Cars are good but Jeremy Clarkson is a dick."
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    I'm running Passat B5.5 aero wiper arms and blades.
    Direct fit. No problem.
    NEW 6 cylinder 40mm front springs - £40
    PM me for more info
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,378
    B5.5 Passat arms work and allow you to fit the OEM aero blades. Have a search though, as i think you might need a different (ie non-passat) blade for one side
    TD5 Land Rover Defender build
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    PM me for more info
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    You don't need to change the blades. This is the second A4 I've run them on without having to change anything.
    PM me for more info
    "Stick a V8 in it!"
    15,378
    cool.
    There was defo something i read about using a different blade on one side, as it has a slightly different position where it attaches to the arm.
    See this thread:
    Passat Aero wipers
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Fair enough, but I've got them on my car right now and they fit/work/look fine.
    But, you do have to make sure that you get the correct arm on the right side, matched up with the correct blade (same length, but different mounting points on the blades), otherwise they will cross over each other.
    PM me for more info
    Biodiesel Purrrr
    Jun 2011
    London
    150
    thanks for rapid replies!
    BTW does this mean I should look for a 99 - 04 Passat?
    I'll see if I can pass by a local breakers this afternoon -
    if not ebay it is...
    P)
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    I think you'll need to search for an '02 Passat onwards. Model is B5.5
    PM me for more info
  1. A6 C6 Avant '07 2.0 TDI - hazard lights switch on and flat battery
    By greg1983 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 26th January 2011, 15:03
  2. S3 MF Flat bottom steering wheel into A4 B8 Avant ?
    By Whiteatom in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 5th December 2010, 20:53
  3. 19s fitted + aero wipers and facelift rears (image heavy)
    By djwillb in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th March 2010, 09:15
  4. B6 Avant Rear Wipers
    By sc00byd00byd00 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th August 2009, 23:56
  5. Facelift A3/S3 service postion wipers!!!
    By harvey183 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th November 2008, 12:32
