Monster MotorsportVolks Autos
    Apr 2011
    13
    2.5 v6 running on biodiesel
    hi all. I've been running my '99 a4 avant 2.5 v6 on 50/50 biodiesel mix since april, covered around 6000 miles with no troubles at all. The only problem it can have is starting in a morning, it sometimes takes for ever to fire up. Once its started though, its fine for the rest of the day. just wondering if anyone else is running a v6 this way and offer any solutions to 1st ime starting!!....
    cheers
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,504
    What are your glow plugs like? Maybe the combustion gasses from the bio fuel is killing or putting a film on the plugs effectively reducing the heat from being transferred?
    2002 2.5 V6 Quattro
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    Is it PROPER biodiesel?
    If so, theres generally no problem running it on a Bosch VE pump as used on the 2.5.
    If your using SVO or filtered WVO thats a completely different story.
    Have you changed your fuel filter at all? Bio can often dissolve various crap from the tank and lines which can clog up the filter.
    TD5 Land Rover Defender build
    Apr 2011
    13
    thanks for the replies. glow plugs could be an idea, its done 151,000 so may need changing. its good bio, been making it for 5 years and not had this problem before, changed the filter after about 2 tanks when i bought it. completely bypassed the glow plugs!!! lol.
    could someone tell me how to check the plugs, is it a case of taking each one out or will it come up as an error code?
    thanks for your help....
    S4_dan's Avatar
    Jan 2006
    1,504
    take the plug out and inspect it, some break down over time. To test, have a spare 12v car battery ready and a jump lead. connect plug to the battery and wait a few secs, should glow red pretty quickly! If it takes time, then change them.
    A bit like spark plugs, always better to replace all rather than just one!
    If you haven't changed them and had the car for a while, then for the price, I'd just change them anyway.
    2002 2.5 V6 Quattro
    Jul 2007
    London
    3,074
    Quote Originally Posted by S4_dan View Post
    be very carefull when removing the glow plugs, theey have a tendency to snap in the head ! Soak them in plus gas/wd40 penetrating oil for a day or 2 and make shure the engine is hot...
    FOR SALE:
  1. Biodiesel
    By ang12el in forum Diesel forum
    Last Post: 16th March 2008, 12:13
  2. BioDiesel in B5 A4s
    By DieselVin in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th January 2008, 19:45
  3. Biodiesel
    By Biggles in forum Diesel forum
    Last Post: 15th December 2006, 12:54
  4. Is anyone using BioDiesel?
    By ianburtney in forum Diesel forum
    Last Post: 10th November 2006, 09:11
  5. Biodiesel ?
    By Amchlolor in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th November 2005, 22:31
Tags for this Thread
