AH FabricationsChris Nott
    Sep 2011
    New ignition barrel and starter motor and alternator - now have headlight issues?
    Since having the ignition barrel and starter motor replaced on my 1997 1.9 tdi A4, I have an issue with the headlights in that when I indicate LEFT, the main / high beams come ON.
    Note: this only happens when the headlight switch is in the 'on' position (i.e. normal lights are on) and only when indicating left. The normal operation of both the indicators and the headlights (ordinary and high beam) and the battery charging is not affected. Also, the fog light button doesn't illuminate - I don't know if this is connected?
    I've been told this is likely to be an 'earth' problem, but I was hoping someone with some expertise could help me with where to start looking? I don't know if any of the components I have changed are connected to the lights?
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    I have a similar problem, but only when the lights are on too. Indicate right and the high beam activates!
    I fitted a cruise control stalk, and this is the result (and cruise doesn't bloody work!).
    I can flash the main beams, but pushing the stalk forwards to activate it doesn't work.
    Weird!
    NEW 6 cylinder 40mm front springs - £40
    PM me for more info
  1. looking to replace ignition barrel
    By B5NUT in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th March 2010, 21:14
  2. Ignition barrel being re-keyed (if that's what you call it)
    Last Post: 11th February 2010, 08:07
  3. Changing ignition barrel
    By harps21k in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st December 2009, 17:51
  4. Key stuck in ignition barrel!
    By Mr K in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th April 2009, 21:07
  5. Ignition Barrel Problems
    By m_o_w_g_l_i in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th October 2005, 19:23
