Volks AutosMonster Motorsport
    Dane's Avatar
    Faster than a V12 Q7
    Cheltenham
    4,003
    First problem :(
    Hi guys first one for you b5 boys, although it probably applies to all cars with the older style recaros.
    I, stupidly, was messing around with my seat position and I raised the height a little. When I went to put it back down nothing happened so to check it wasn't buggered I pressed the up control and it went up but it still wont go down...
    I've had a good look around for disconnected wires but I can't see anything obvious, anyone heard of anything similar/know of a fix?
    Cheers,
    Dane
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,287
    Theres a microswitch that tells the mechanism that its at its lowest point and to cut off the motor, perhaps this is stuck?
    Alternatively the down switch might just have broken!
    TD5 Land Rover Defender build
    Dane's Avatar
    Cheltenham
    4,003
    Thanks Aragorn, but I have unexpectedly fixed it.
    Having searched and searched, there are micro switches that I guess tell the motor when the chair has reached its maximum and minimum points.
    The only one I could see is at the rear of the seat on the door side roughly in line with the seat belt feed.
    it looks like this
    Now first of all I tried pushing it in a few times and that didnt work, I tried holding it in and using the button but that didnt work either. fortunately I held the down button and released the switch and it then moved a bit but then stopped, so a few repetitions and its now back down.
    Theres a fabric cover under the seat, its a good Idea to reattach it before you put the seat all the way down lol. Hopefully it'll help someone in the future...
    thanks to this thread electric recaro problems which contains this http://users.ox.ac.uk/~engs0330/car/a3_interior.pdf Recaros are from page 72-116 onwards
  1. problem after problem... juddering...
    By ian 06 A3 2.0 tdi s line in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th January 2011, 21:09
  2. Update on problem and another problem!!!
    By evilbane in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st December 2010, 00:10
  3. Replies: 1
    Last Post: 21st August 2010, 19:41
  4. brake binding problem / abs light problem
    By brendan in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th November 2008, 20:24
  5. A4 Tdi, engine problem AND steering problem! PLEASE help!!
    By mattsavage in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th February 2007, 16:02
