Sky InsuranceEM Tuning
Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By spartacus 68
  • 1 Post By PAULF
Thread: Quattro ABS Sensor woes...
    May 2010
    Val d'Isere
    85
    Since destroying the front ABS sensor thinking I had to remove it during a CV boot change it took some care with a rubber mallet to reinstall the new one into its new copper cage.
    Is this normal?
    Although I haven't paid too much attention to measurements it seems to have gone in ok (I didn't push it too far) and no longer have the ABS dash light on.
    Does lack of warning light mean everything should be fine safety wise?
    Thanks in advance.
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Sounds like you've nailed it.
    NEW 6 cylinder 40mm front springs - £40
    PM me for more info
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,379
    It should just slide in.
    The upright gets rusty though, and the rust makes the hole smaller. Ideally you'd have used a round file to clean out all the crap and fitted a new brass sleeve.
    TD5 Land Rover Defender build
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    "Rust makes the hole smaller"... tee hee!
    PM me for more info
    May 2010
    Val d'Isere
    85
    Pulsating brake pedal getting worse but no ABS light?
    Sorry to resurrect this thread.
    Although I have had the ABS light on the dash I haven't seen it for a long time now; However, the pulsating at slow speeds is progressively getting more frequent.
    Would you blame the ABS module in this case or the sensor?
    Thanks in advance.
    "Stick a V8 in it!"
    15,379
    Pulsing at low speeds is usually a damaged reluctor.
    If its a quattro its likely a rear one.
    spartacus 68's Avatar
    Dec 2008
    Aberdeenshire
    254
    Agree with aragorn's suggestion and split reluctor ring. Remove driveshaft - by undoing splined bolts at inner cv joint.
    Did the same job myself last year. Remove existing ring, and thoroughly clean area prior to fitting new ring, a light smear of grease will help too. Heat the new ring with a blow torch until cherry red. Fitting it cold is likely to pose problems.
    Looks like this.
    PAULF likes this.
    2002 A2 1.4 TDi SE (125k)
    2001 A4 2.5 TDi Avant Quattro Sport (155k)
    1995 80 TDi Avant SE (175k) Sold
    May 2010
    Val d'Isere
    85
    Thanks both of you. As the light isn't on is this likely to be an MOT failure do you know?
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,136
    If its not on and the decelerometer readings are good i shouldnt see why it wouldnt pass TBH !!
    Jan 2011
    Aberdeenshire
    646
    Mine passed with it pulsing no problem. I did change one of the Avant rears for new and repaired the other rear Avant and one rear saloon as they weren't cheap (Mentioned in here - How to replace front and rear suspension parts (with pics) )
    Beware though, it takes somebody from Aberdeen to save money by repairing these
    As Spartacus says, you need to clean the seat well and heat the ring to cherry red. Pop it on and push it home with an old screwdriver or similar.
    spartacus 68 likes this.
    1999 A4 B5 1.9 TDi FWD Saloon, Green SOLD
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine - and gearbox )
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    2006 A6 Allroad 3.0 TDi Blue, awaiting stuff to be done!
  1. Replies: 2
    Last Post: 25th June 2011, 12:13
  2. A4 Quattro ABS Sensor siezed but rotates..??
    By SilverSaloon in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th November 2010, 23:51
  3. 2.5tdi quattro coolant sensor?
    By Leea4tdi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th November 2009, 09:39
  4. 80 quattro insurance woes
    By leebex in forum Classic Audi Forum
    Last Post: 18th April 2004, 18:42
  5. 1985 4000S Quattro 5cyl Oxy Sensor light came on
    By spanky442 in forum Classic Audi Forum
    Last Post: 22nd January 2004, 21:07
