Sky InsuranceEM Tuning
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By NineNails
Thread: S4 O/S/R brake binding... smoke!
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Just got to work in the S4, opened the car door and thought... "that's a strange brake-like smell"
    Looked at the back wheel and it was smoking! Looks like the brake has been caught on while I've been driving. I thought it was weird when I pulled the handbrake on and it was really 'easy' to activate. Thought it might need adjusting, but I guess not.
    Is there a quick way of releasing it as I'll be stuck at work otherwise...
    Cheers,
    Giles
    NEW 6 cylinder 40mm front springs - £40
    PM me for more info
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,350
    The handbrake spindle often siezes. Look thru the wheel at the top of the caliper, and theres a little metal arm and a plastic stop. With the handbrake OFF the arm should sit 1mm away from the stop. If its siezed its likely the arm has remained in the "on" position.
    If you use a screwdriver or similar to push the arm back against the stop, you should be able to drive it so long as you dont touch the handbrake lever.
    TD5 Land Rover Defender build
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Brill... thanks!
    PM me for more info
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Wasn't that thingy... it was both calipers. One wasn't doing anything (and hadn't for a while apparently) and the drivers side had just stuck on. Managed to source some new ones. £270 fitted for both sides.
    Bit annoying as I've only had the car 3 weeks... but just one of those things I guess.
    PM me for more info
    "Stick a V8 in it!"
    15,350
    As i said on SRS, i'd be considering upgrading to facelift calipers rather than spending that much on the crappy PFL ones.
    AndyC's Avatar
    Apr 2003
    Dorset
    716
    the internal mechanism is complex and often jams, I tried to free mine off...... no chance.... i gave up and bought a new one from GSF...
    there is no such thing as bad weather, just the wrong clothes!!
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Two new ones installed. Not smoking now!
    PM me for more info
    AndyC's Avatar
    Apr 2003
    Dorset
    716
    glad you sorted it.
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    579
    I would be wanting to change the brake fluid too
    AndyC likes this.
    2000 1.8t quattro Sport totally standard (ish)
  1. More smoke from the S4!!!
    By nemo2182 in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th September 2011, 08:55
  2. SMOKE FROM THE OIL CAP? 2.5 V6 Q 180
    By swarcup in forum Diesel forum
    Last Post: 19th March 2011, 20:33
  3. brake binding problem / abs light problem
    By brendan in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th November 2008, 20:24
  4. Do you Smoke?
    By Defratos in forum General Chat
    Last Post: 27th February 2007, 22:11
  5. Up In Smoke!!!
    By lilegbeaner16 in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th May 2004, 05:33
