JMB RetrofitsVolks Autos
Results 1 to 33 of 33
    skinz's Avatar
    May 2011
    leicester, uk
    233
    Temp gauge not working
    My temp gauge has stopped working, I think it could b the thermostat or the temp sender but not sure where these are, any help would b much appreciaated, or if u have any other ideas what it could would help cheers
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,350
    If its the thermostat, the gauge will rise if the cars left idling.
    To test it, drive around for 10mins or so, then park up and leave the engine running for 5 mins. If the gauge comes up the stats gone, if it doesnt its probably the temp sensor.
    TD5 Land Rover Defender build
    skinz's Avatar
    May 2011
    leicester, uk
    233
    Looks like it's the temp sender, where is it on the AEB engine
    skinz's Avatar
    May 2011
    leicester, uk
    233
    the dash temp gauge is for the water temp not the oil
    "Stick a V8 in it!"
    15,350
    its on the back of the cylinder head, sticks out of a plastic elbow with a four pin plug on it.
    skinz's Avatar
    May 2011
    leicester, uk
    233
    cheers found it, had a quick look on fleebay an cant seem to find 1 that matches mine
    "Stick a V8 in it!"
    15,350
    What year is your car?
    skinz's Avatar
    May 2011
    leicester, uk
    233
    n reg 96
    "Stick a V8 in it!"
    15,350
    Hmm ETKA is a bit vague.
    Its either 058919501A (black) or 059919501 (blue)
    It suggests the black one is used upto the end of chassis code T, then the blue one is used from V onwards.
    skinz's Avatar
    May 2011
    leicester, uk
    233
    the stump bit is really thick and its black (that sounds really wrong lol), all the 1's i've seen are thin
    "Stick a V8 in it!"
    15,350
    Aug 2010
    cornwall
    44
    mine seems to have stopped working for the last week or two aswell, although it climbed to 65c this morning ?? am i looking at a thermostat replacement?
    skinz's Avatar
    May 2011
    leicester, uk
    233
    nether of them 2 look like mine, ill put a pick up in a bit
    "Stick a V8 in it!"
    15,350
    Murdoch: as i said above, have a drive to get some heat into it then leave it idling for 5-10mins and see if the temp comes up to 90.
    If it does, its the stat.
    skinz's Avatar
    May 2011
    leicester, uk
    233
    Can't seem to add pics
    "Stick a V8 in it!"
    15,350
    upload them to photobucket or imageshack then post the link here?
    skinz's Avatar
    May 2011
    leicester, uk
    233
    At the bottom where it says posting permission it says I'm not aloud 2 add attachments, does that mean I can't put pics on, cause I click when I click on the image icon it don't do anything
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Mine had similar symptoms. Changed the temp sender and it was fine.
    Also changed the thermostat, just to make sure!
    NEW 6 cylinder 40mm front springs - £40
    PM me for more info
    "Stick a V8 in it!"
    15,350
    dont bother trying to upload them to the forum. Upload them to photobucket or image shack and paste in the link.
    Aug 2010
    cornwall
    44
    did so last night, no change in the reading, didn't go above 60c !
    "Stick a V8 in it!"
    15,350
    sounds like it could be the sensor then. Do you have climate control?
    If so, press and hold recirc, and press the up arrow, the display will change to 1c, use temp +/- to change it to read 49c then press recirc again.
    The display will then change to show the real coolant temp. See what that shows?
    skinz's Avatar
    May 2011
    leicester, uk
    233
    Went Audi today and took my sensor with me an they said they had 2 order the sensor in and gave me the part no. Which is 058 919 501a which is the 1 u said but it don't look like mine
    "Stick a V8 in it!"
    15,350
    could be revised over the years?
    skinz's Avatar
    May 2011
    leicester, uk
    233
    Aug 2010
    cornwall
    44
    ooh ooh, i like playing with buttons!! I will have a look at it tomorrow cheers
    Aug 2010
    cornwall
    44
    had a go with the climate thingy, and it read the same as the gauge, never went above 62c, is that a new sender or thermostat?
  28. #27
    "Stick a V8 in it!"
    15,350
    did it sensibly climb up to 62 though?
    Ie start at 10-15c then climb steadily?
    Also, switch the AC off when testing, as with the AC on it runs the radiator fan all the time, and this will further reduce the temperature if the stat is stuck open.
  29. #28
    Aug 2010
    cornwall
    44
    I don't know, because I only got a chance to set it up at some roadworks, by which time it was up to 62c.Thanks, I will try that tomorrow, and have the ac off too!!
  30. #29
    skinz's Avatar
    May 2011
    leicester, uk
    233
    i dont have ac i dont think, but my fan is on all the time, should it b on all the time
  31. #30
    Aug 2010
    cornwall
    44
    Yes, the temp climbed steady to 65c, then fluctuated between 62-57c with all heating etc off, I lifted the bonnet whilst it was idling at the end of the journey, and noticed the fan was continuously on, is that normal?
    Skinz, sorry to jump on your thread, i thought it would be a good idea to keep it all in one, as it's effectively the same problem.
    Aragorn, thanks for helping !
  32. #31
    skinz's Avatar
    May 2011
    leicester, uk
    233
    No worries bud if it helps u out as well, I've got my mot coming up so just trying to get everything sorted for that, got my wish bones, ABS sensor an cv boot to sort out next, I'm hoping that's it all sorted for mot then
  33. #32
    "Stick a V8 in it!"
    15,350
    Which fan?
    There are two. One large fan bolted to the engine and driven by the aux belt, and a smaller electric one.
    The big fan runs all the time, but has a viscous coupling and should only run slowly with the car at normal temperatures. The small electric fan should only run when the coolant temp is over 95c or when the AC is on.
    It does sound like the thermostat, especially if the bits where it dropped lower than 65 where high speed low load, like crusing on the motorway. Its odd that it wont climb when idling, but i guess if the stat was really jammed open the fan may well be drawing enough air thru the rad to keep the temperature from climbing any higher.
    The one last check you could do, would be to use vagcom to compare the ECU temp reading with the instruments, if they're the same its almost certainly the 'stat.
  34. #33
    skinz's Avatar
    May 2011
    leicester, uk
    233
    Went an got the temp sensor this mornin an it's all workin again, cheers for ur help (memo to self: don't take out temp sensor when engine is warm :-/
  1. Temp gauge stopped working?
    By aterro in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th May 2011, 16:49
  2. temp gauge not working :(
    By S3_nick in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd January 2011, 16:55
  3. 95 1.8n/a temp gauge not working?
    By andybnwc in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th October 2008, 22:36
  4. Temp gauge not working...
    By NILESH in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th May 2007, 01:33
  5. temp gauge not working
    By nickstevens in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd November 2005, 01:52
