Thread: abs issue
    Feb 2009
    228
    abs issue
    hello, after replacing my rear disks/pads this week i'm getting the abs module pulsating under 10 mph on light braking.
    The old abs rings were re used and i suspect this is the issue, the garage who fited the disks re checked and cleaned the sensors for me to try to resolve but it's still doing it. I have ordered 2 new rings which should be on by tuesday, do you think this is likely to solve the problem?
    I put vcds on and notices 2 things:
    1) the r/o/s wheel seems to be slower to respond to changes in speed - would this cause the issue? and;
    2) i kept getting kicked out of the abs control module when the vehicle was moving - is this the way it's supposed to work, low speed only?
    i ran the car with the abs fuse out for a few hundred yards and the brakes were fine (as expected) but the light and buzzer sounded.
    what's your money on, sensor or rings?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,933
    1- The rings probably damaged. However it might be that the sensor is covered in crap, or has been pushed back away from the ring.
    2- yes thats normal, it cuts off at about 10kph
    TD5 Land Rover Defender build
    Feb 2009
    228
    sorted, right rear abs rotor replaced and normal business resumed.
  1. tow bar issue
    By stuhow3361 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th July 2010, 20:41
  2. ABS issue!!
    By dan1973 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th November 2009, 13:27
  3. ABS Issue?
    By rgvn in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th November 2009, 14:32
  4. DIS issue?
    By Jpc in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th April 2007, 11:04
