hello, after replacing my rear disks/pads this week i'm getting the abs module pulsating under 10 mph on light braking.
The old abs rings were re used and i suspect this is the issue, the garage who fited the disks re checked and cleaned the sensors for me to try to resolve but it's still doing it. I have ordered 2 new rings which should be on by tuesday, do you think this is likely to solve the problem?
I put vcds on and notices 2 things:
1) the r/o/s wheel seems to be slower to respond to changes in speed - would this cause the issue? and;
2) i kept getting kicked out of the abs control module when the vehicle was moving - is this the way it's supposed to work, low speed only?
i ran the car with the abs fuse out for a few hundred yards and the brakes were fine (as expected) but the light and buzzer sounded.
what's your money on, sensor or rings?
