AH FabricationsJMB Retrofits
Page 3 of 3 FirstFirst 123
Results 81 to 120 of 120
Like Tree2Likes
Thread: new turbo
  1. #81
    Blackie's Avatar
    Feb 2004
    In a house
    634
    My turbo whistles so i just live with it.
    When i first got my A3 the turbo whistled & everyone said its was fooked. I spent x amount on a brand new unit & x amount again on fitting. It was fitted & same noise so i know the turbo is ok.
    It can be sat idling & all quiet then the panpipes start. If i blip the throttle it stops again for a bit.
    Driving along it whistles whilst it spinning up & when cold i can hear the DV. I know the turbo is ok so i,m not worried about it.
  3. #82
    Sam
    Oct 2011
    Bomber County
    37
    There should be a little more lag from the K03S due to it been a larger turbo but not kicking in until double that of a k03 is mental. You almost definately have a boost leak, try smothering ALL intake and feed pipes with a mix of fairy liquid and water. If its the pipe clips I reccomend replacing them all with mikalor hose clamps as you can get them much tighter and they tidy things up alot too.
    I would also recomend checking your boost actuator which would also go to explain overboost.
  4. #83
    skinz's Avatar
    May 2011
    leicester, uk
    232
    The new turbo is all plumbed in and guess what still getting the same whistle, so it's got to be a boost leak, might just buy some new silcone hoses, would that washing up liquid work when its not boosting, would it work just by revving it, just changed the alternator cause that was whining now it wants to whistle, what's it gonna do next
  5. #84
    skinz's Avatar
    May 2011
    leicester, uk
    232
    was gonna spray around the pipe work with some soapy water today but then thought.... these hoses get air sucked through them not blown through so i wouldnt get any bubbles, it would just suck the water in the air leak, am i right in thinking this??
  6. #85
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,113
    No as it's boosting so it's forcing air through the pipes at a high pressure to fill the cylinders with as much air as possible hence why the pipes expand when boosting. But you may not find out at idle as it may only leak at a certain boost pressure when there is load on the engine as you won't create any boost at idle.
  7. #86
    skinz's Avatar
    May 2011
    leicester, uk
    232
    wouldnt that push air back through the airfilter though??? is there a way i can check where the leak is coming from??
  8. #87
    Aug 2010
    3,113
    No as the turbo is sucking the air from the filter to create the boost in the pipework you can do a boost leak test by taking the oil cap off, remove the pancake/hockey puck valve of the intake and blank the pipe then get something that will go over the MAF housing with a tyre valve in it then charge the system through it with a tyre gauge but don't go past 15psi a you may blow seals so it's a good idea to have someone watch your boost gauge whilst you check your pipe work.
  9. #88
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,317
    as i said before, you need to perform a boost leak test.
    Use something like this, with a compressor or airline:
    Turbo Boost Leak Tester - kit for all turbo cars | eBay
    TD5 Land Rover Defender build
  10. #89
    Aug 2010
    3,113
    I DIY'd my own -
    It was one of the blanking caps of the exhaust extractors at work it had a whole already in it so just pulled a tyre valve through and it's as tight as a nuns **** lol and fits perfectly on the MAF housing with a jubilee and then just found something to bung the intake pipe up. Worked a treat.
  11. #90
    skinz's Avatar
    May 2011
    leicester, uk
    232
    gonna take a trip round some hardware stores tomorrow see if i can find something to make this boost leak tester, watched a couple of vids on youtube showing a couple of ways to make them, car went for its mot yesterday an failed on emissions, im hoping its down to the boost leak, emissions are always a ball ache trying to sort out
  12. #91
    Aug 2010
    3,113
    Ye theres a few i found this one useful HOW TO BOOST LEAK TEST on an AUDI A4 1.8T - TurboBoostLeakTesters.com - YouTube
    diameter is about 2.75 inch for the MAF iirc
    Hope you sort it mate.
  13. #92
    skinz's Avatar
    May 2011
    leicester, uk
    232
    yea seen that 1, found this as well, this is what im gonna try an make
    Boost Leak Testing 101: Building the tool. - YouTube
  14. #93
    skinz's Avatar
    May 2011
    leicester, uk
    232
    there's a boost leak test on there done on a TT and they used a bean can, i just tried this an it squashed the can, the only thing i can think of to what they did is drill a hole in both ends, where as i used 1 of them where you have a pull ring to pull the lid off
  15. #94
    "Stick a V8 in it!"
    15,317
    What was your CO2 figure on the emissions test?
  16. #95
    skinz's Avatar
    May 2011
    leicester, uk
    232
    they didnt give me the emissions sheet
  17. #96
    "Stick a V8 in it!"
    15,317
    Thats kinda useless then!
    A lot can be gleaned from the figures on the sheet. A failed cat would give different figures to a faulty lambda sensor or MAF for instance.
    Without that info your just guessing at any number of possible causes.
  18. #97
    skinz's Avatar
    May 2011
    leicester, uk
    232
    i know im gonna go bk tomorrow an see if i can get it or get another 1 done
  19. #98
    skinz's Avatar
    May 2011
    leicester, uk
    232
    i went round all the local stores, pochins, B&Q, buildbase, homebase and a couple others and couldnt find anything, gutter down pipe was just the right size but couldnt find anything to cap the end, so went home to make a cup of coffee an when i opened the suger jar i thought if i could get something like this in the right size it would do the job, so shot out down the nearest tic-tac shop an found this
  20. #99
    skinz's Avatar
    May 2011
    leicester, uk
    232
    found a leak, it was coming from 1 of the injectors, the far bk 1
  21. #100
    skinz's Avatar
    May 2011
    leicester, uk
    232
    never touched the injectors before, does this mean its just come lose an needs pushing bk in or has a seal gone and i need to replace it, is it hard to remove
  22. #101
    skinz's Avatar
    May 2011
    leicester, uk
    232
    got my emissions sheet off the mot place
    min max
    fast idle test
    CO level 9.87% fail -- 0.30
    HC level 301ppm fail -- 200
    lambda 0.75 fail 0.97 1.03
    second fast idle test
    CO level 10.41% fail -- 0.30
    HC level 342ppm fail -- 200
    lambda 0.73 fail 0.97 1.03
    natural idle speed
    CO level 3.09 fail -- 0.50
    think i failed my emissions
  23. #102
    skinz's Avatar
    May 2011
    leicester, uk
    232
    oh and my manifold has got a crack in it now, i did find a secondhand 1 on fleebay but it says its for the apu engine would it still fit the aeb engine
    jamie226bhp likes this.
  24. #103
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,505
    It will fit yes, but its small port. Fine if no future upgrades planned.
    I'd be more worried about the high C02 etc, signs of a worn engine or blocked breather
  25. #104
    "Stick a V8 in it!"
    15,317
    At a guess, your lambda sensor is fried.
    That or there is a major leak pre-lambda.
    The HC's are sensible, which means the engine IS burning the fuel, theres just far too much of it.
  26. #105
    skinz's Avatar
    May 2011
    leicester, uk
    232
    need a vagcom really then
  27. #106
    skinz's Avatar
    May 2011
    leicester, uk
    232
    Vagcom ordered should get that sometime mid week, are them manifolds any good on fleebay? Rang around and most places don't sell them
  28. #107
    skinz's Avatar
    May 2011
    leicester, uk
    232
    i do get a strong smell of petrol if i give it high rev's, seen this on ebay but not to sure cause of some of the tac you can get on fleebay
    AUDI A4 PASSAT 1.8T K03 K04 STAINLESS STEEL EXHAUST EQUAL MANIFOLD LONGITUDINAL | eBay
  29. #108
    Aug 2010
    3,113
    Id go for an ATP high flow manifold eBay number 200623006159 which is similar to the FT one I have but then you need longer bolts or threaded bar and nuts.
    Here's mine
    I have a my old standard manifold at work ill check for any cracks and you can have it if you cover postage PM me if interested.
  30. #109
    skinz's Avatar
    May 2011
    leicester, uk
    232
    sweet cheers bud, pm sent, why is it blanked off where there turbo bolts on
  31. #110
    Aug 2010
    3,113
    That's a from the top view. The port is underneath here's a pic of mine fitted as you can see it's nearly double in size to the oem manifold hence why you have to use threaded bar and nuts as the rear bolt closest to the engine I had to insert the threaded bar from the bottom wind the nut as much as I could up top then align the turbo upto it as the bar won't clear the rocker cover wasnt that bad of a job to do and didn't struggle to say that some ppl have said there a b****** to fit.
  32. #111
    skinz's Avatar
    May 2011
    leicester, uk
    232
    ahh i see now
  33. #112
    May 2010
    Bedford
    2,877
    You can use the BEX coded manifold aswell cant you? Thats bigger than the B5 1.8t manifolds so should flow a bit better. Or buy the THS manifold which is based on the ATP item im sure.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
  34. #113
    skinz's Avatar
    May 2011
    leicester, uk
    232
    sorted out out the vagcom (what a ball ache to install) and its come up with 8 fault codes, here goes
    18010 - P1602 - power supply (B+) terminal 30 low voltage
    16500 - P0116 - engine coolant temp. circ range/performance
    16518 - P0134 - 02 sensor circ. bank 1 - sensor no activerty detected
    17978 - P1570 - control module locked
    16705 - P0321 - ign/distributor eng. speed inp. circ range/performance
    00561 ???? couldnt find this 1
    00670 ???? think this 1 is throttle position sensor
    16705 - P0123 - throttle/pedal pos. sensor A circ high input
    ABS
    00290 ????
    00287 ????
    cant any1 give me any help with these plz
  35. #114
    Aug 2010
    3,113
    00561 is to do with mixture adaptation iirc had this on mine when the gasket blew on the decat when I didn't tighten up the b**** of a nut under the manifold properly. Replaced it when I did the FT conversion and haven't seen it since.
    I'd be clearing the codes going for a 10min drive and then see what pops up.
  36. #115
    "Stick a V8 in it!"
    15,317
    As above you need to clear them, then see what comes back. But the mixture/lambda codes will likely be the cause of your emissions.
  37. #116
    skinz's Avatar
    May 2011
    leicester, uk
    232
    some1 on here had a link for rosstec page with all the fault codes, really good sit, helps out loads, way better than the 1 for op-com, i know 1 is the boost leak and the cracked manifold and another 1 i think with my old turbo being fuk'd has clogged up my lambda sensor, another 1 is my immobiliser playing up, another being a air leak on 1 of my injectors, need to change both rear ABS sensors.
    not sure about these though 16705, 00561, 00670
    this is the web page
    Category:Fault Codes - Ross-Tech Wiki
  38. #117
    skinz's Avatar
    May 2011
    leicester, uk
    232
    yea 00561 comes up with boost leak as a possible fault, i found that ive got a hole in my exhaust some where near the cat/flex on my middle pipe, not had a chance to have a look where its coming from
  39. #118
    "Stick a V8 in it!"
    15,317
    Clear the codes away, and then drive the car for 15mins and scan again.
    The ECU will store codes up, and will show them even if they're no longer relevant.
    If you clear them, then any that come back need immediate attention.
  40. #119
    Aug 2010
    3,113
    Clear the codes as you may be pissing in the wind with some fault codes.
    Then see what codes you have to be sure you are checking the right fault codes for your faults !!
  41. #120
    skinz's Avatar
    May 2011
    leicester, uk
    232
    ok i'll give it a run tomorrow an let you know
  1. Hybrid: CR Turbo Vs Turbo Dynamics
    By Lemon S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th March 2013, 19:51
  2. Fitting 1.8 turbo into non turbo ( got donor car)
    By yam426 in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th October 2010, 22:48
  3. BEST GEARBOX AUDI A3 TURBO , GOLF GTI TURBO
    By needforspeed in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th September 2009, 23:13
  4. turbo gargle - turbo problem symptoms?
    By sinbadfury in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th July 2006, 19:49
  5. S-Line Turbo - Which turbo does it have????
    By A4T in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th August 2004, 19:52
