Chris NottAH Fabrications
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    577
    Boost Gauge Question
    Evenin all
    Ok so I finally got round to fitting the boost gauge (not done oil pressure yet) but I'm not sure if it works ok or if there's a problem with the motor. The gauge reads just off the bottom of the dial at idle and off throttle at 30 inHG and goes up to about 11 psi when I boot it in 3rd but the needle waggles about between 9 to 11 psi whilst being booted. I think I'm missing a couple of psi but the gauge may not be that accurate I suppose. Is the vac reading ok or should it not be as much as this?
    Thanks for any info
    Si.
    2000 1.8t quattro Sport totally standard (ish)
    May 2010
    Bedford
    2,877
    11 sounds about right for a non mapped 180bhp engine to be honest on peak boost. Vac a lot of peoples seem to vary to be honest.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,907
    to cure the wiggling you can try putting a restrictor in the feed line to the gauge.
    TD5 Land Rover Defender build
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,919
    ^ What he said.
    Life begins at 140mph
    www.passionford.com
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,873
    On idle mine sits at 20inhg on overrun it's at 22inhg, and will boost to around 14psi but some times due to load will see 10-12psi and mine sticks at 10 with a tiny bit of needle wobble but doesn't go to nine unless I'm really running out of revs, and my t-piece has the brass restrictor on it to you may have a tiny leak if your vac is on 30inhg but as Jason says many peoples vary.
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    NineNails's Avatar
    Sep 2006
    North Wales
    577
    Thanks for the replies. It has a restrictor in the tee piece but I might try putting one in closer to the gauge. Bradderz, I don't think I have any leaks to the gauge but if I did surely it would read less as I would be loosing vac?? It's a shame it has such high vac pressure as it makes the gauge look a bit pants sat there with it's needle off the bottom of the dial. I was just seeing anyone else had this or if maybe the gauge was faulty but as it seems to read boost correctly then I suppose I must assume it works ok... Oh well
  1. DEFI Racer Boost Gauge install question
    By *ace* in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th September 2011, 10:47
  2. Boost leak, Weak Actuator or boost gauge?
    By DaveA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th July 2011, 13:51
  3. Replies: 0
    Last Post: 17th January 2011, 21:00
  4. Boost gauge only reads negative boost?
    By garyrmills in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th October 2009, 21:45
  5. Another boost gauge question (again)
    By jojo in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th July 2004, 22:13
