EM TuningSky Insurance
    nemo2182's Avatar
    Lord wont u buy me a V10 R8!
    Oct 2005
    uk
    110
    More smoke from the S4!!!
    Evening all,
    I posted a thread a few months ago regarding my S4 puffing blue smoke when starting.....
    Well, the story goes like this
    I had a oil service recently, and put a engine conditioner through to "hopefully" clear the problem which was believed to be a hard valve stem seal. I decided to put a 5w 40 oil in also, as I know MRC recommend this on tuned b5's.
    anyway, once done, start her up and heypresto, no smoke..........brilliant i thought......
    Thing is now, i get smoke coming out the back of engine, from where the turbo lives???? Now, its defiantly burning oil, but I have no idea where from?? is the oil inlet pipes? is the turbo f@cked? thing is, still goes alright and doesnt smoke out the back? I have noticed it gets a fair bit of black soot on the tailpipes though?? Now it is using a bit of oil, but not as much as I expected when seeing the volume of smoke that comes out of it? I have to admit, it does seem to go when the car is warm.
    This car is really upsetting me, I treat her so well......... Anyone want to make me an offer and take her on......
    Any help would be appreciated
    Nathan
    2000 B5 S4 - MRC Remap - RS2 Sparks - Pipercross Element (dried) + Modified Airbox - Forge Divs - Samco Hose's - KW's dropped 50mm - 18" RONAL R41 in gun metal grey - Black Diamond Combi Disc's + Predator Pads - Brushed Alloy Mirrors - Short Shifter - Full Recaro - Carbon Trim - Bose. More to come, watch this space.......
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,381
    Back of the engine could be one of the cam tensioner gaskets, or it could be a leak on one of the turbos oil lines?
    TD5 Land Rover Defender build
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    Black soot on the exhaust tips is more just likely to be from your car running a little rich at full boost. Could point to a boost leak, or could be perfectly normal. I know MRC intentionally keep their maps a little rich at the top end for safety.
    The only other suggestion I would make is the rocker cover gasket. These are prone to failure. Mine have gone a couple of times in my ownership and each time the leak was at the back corner and allowed oil to drip onto the manifold. How much smoke are we talking here? Is it visible, or can you just smell the burnt oil?
    If the oil feed is leaking as Aragorn has suggested, I would expect to see a little bit of oil on the underside of the turbo. This is what mine looked like when I had the problem:
    I don't think that will be your issue though, as you mention the smoke goes after a while.
    Mo power, mo problems
  1. Do You Smoke?
    By Ritch7 in forum You Tube Links
    Last Post: 25th August 2011, 10:35
  2. SMOKE FROM THE OIL CAP? 2.5 V6 Q 180
    By swarcup in forum Diesel forum
    Last Post: 19th March 2011, 20:33
  3. Do you Smoke?
    By Defratos in forum General Chat
    Last Post: 27th February 2007, 22:11
  4. TOO MUCH SMOKE
    By DIPS_A4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st September 2006, 20:47
  5. Up In Smoke!!!
    By lilegbeaner16 in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th May 2004, 05:33
